Not always, but you can run the KOEO (Key On Engine Off) and KOER (Key On Engine Running) tests and you should get code 14 (I believe) if the PIP is failing. If you don't know, the KOEO and KOER tests are built-in to the Ford computer; you can get a cheap code reader from most car parts stores that will run these tests for you.
