Falling sunroof
  • Thread starter Thread starter ASH5OH
  • Start date Start date Jun 1, 2005
A
ASH5OH
Pennsylvania
Jun 1, 2005
  • Jun 1, 2005
My sunroof always falls back down when I go over bumps, is this a common occurance with you guys too??
ss93cobra
1,422
Wilmington NC
Jun 1, 2005
  • Jun 1, 2005
Not here nor in any I've seen or owned.
camarokiller5.0
48
Dallas
Jun 1, 2005
  • Jun 1, 2005
Not mine,never has, you can do some minor adjustment to it, take the plastic cover off and loosen the screws and adjust it, Good luck!!
P
PonyBoy90
555
Toronto
Jun 1, 2005
  • Jun 1, 2005
I just dismantled my sunroof a few weeks ago to cure a little leak I had at the base of one of the holes where the screw goes through to the retainer on the otherside.
By dropping, I take it you mean when you release the clasp and flip it up to "prop" the sunroof on it, hence when you hit a bump, the clasp flips back/or drops and the sunroof drops with it right?
I believe 100% your problem has to do with the springs on the clasp which retract and extend the hinge mech to the roof of your car.
In order to take your sunroof off your car, you need to release the clasp. With the clasp hanging down, from the back you should see this chrome plated hinge with hooks on each end that fit into slots in the plastic clasp on the roof of your car with a spring spooled around the chrome hinge. That spring is there to provide some tension for when you lock the sunroof either when you close/lock it, or when you open your roof and "prop" it. Sounds like either your spring is worn out, OR, you have NO spring at all, OR something on your clasp is either cracked or broken off.
If you need to change your spring, or the whole clasp, REMEMBER, first you must loosen the allen key bolt on the side of each phillips screw/bolt. There's one for each and they go through the plastic into the bolt. IF you don't do this first, you may shatter your sunroof. Once you've done this, you can unscrew and dissassemble your sunroof lickity-split.
Upon tightening on re-assembly, be very very gentle. You only need to tighten enough to make contact between the retainer plate on the outside of the glass. Add some sylicon around the holes to prevent leaking. The allen keys are what stop the screws/bolts from loosening. These you can tighten a little more.
Good luck
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Fox Dome Light for an 84 GT Hatchback with Sunroof
  • handymancanfixit
  • May 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 21, 2025
handymancanfixit
87-93 Mustang T-top/Sunroof production numbers
  • Mustang5L5
  • Jan 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Mustang5L5
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Resolved TermX AFR pegged lean after winter storage
  • Kid wita 5oh
  • Apr 4, 2025
Fox 5.0 Mustang Tech Apr 9, 2025
Kid wita 5oh
