Fan always running... SCT X3?
Blue89ELEX
23
I just loaded in an SCT X3 "strategy" tune. Now, it seems like my fan is running all the time. I checked both of the engine/fan temperature settings inside the X3, and both seemed normal (don't remember exact, but fan low/high about 170*F/220*F)...
Still, the fan starts about 10 seconds after the engine starts, and runs until I turn the engine off. I thought it may be a bad sending unit, but my dash temp gauge seems to read normal...
Any suggestions? Thanks!
The stock low speed fan is supposed to come on at 198 as i recall. The stock 192 degree thermostat means that at 170 it *is* going to run all of the time. The 220 on the high speed sounds right. I can check mine tomorrow if you need me to.
EDIT:
I'll be sure to check mine today. I'll post up this afternoon when i get home.
I'd flash it back to stock and reflash it - sounds maybe like the tune did not get loaded all the way or something got corrupted along the way. The fan runs during a flash all the time so that sends up a red flag to me. If that doesn't work, call SCT tech and see what they can do for you - maybe the canned tunefile got corrupted in the unit.
Dunno your year of car, but typically a 'new edge' PCM, this one is a GTG3 stock turns on high speed at 228*, low speed at 206* - this is pretty much around what a lot of them are set to. There are other factors that control it such as load and MPH. There is usually a startup delay as well. SCT's base files lower the HS to about 210* and the LS to 200*.
If you modded the fan temps via the handheld, I'd put them back to where they were originally you'll burn the fan up running it all the time.
Don
My car (2000 GT) defaults to 198 for the low and 206 for the high. I bumped mine down to 196 and it comes on when stuck in traffic about 2 degrees before it used to. 170 is the lowest option on the low speed fan which makes me think you accidentally selected it. Reflash with the above values and you should be fine.
