Fan Clutch Problems
  • Thread starter Thread starter Strype
  • Start date Start date Apr 13, 2007
1 of 2 Next Last
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
Hey guys I took my electric fan off and I put my stock fan back on. Here's what happened:
1) Took e-fan off and put stock fan on with new clutch.
-Car surged horribly and died. Surges even when I press the gas.
2) Took stock fan off and cranked car w/o fan.
-Car idled perfectly and ran great
3) Took new fan clutch back and replaced with another new one.
-Car surged horribly and died over and over again. Surges even when I press the gas.
4) Put old OE fan clutch back on car.
-Car surges still and dies. Even surges when I press the gas.
So... Has anyone run into this problem???
-I'm fairly sure the fan is not on backwards. If anyone has a pic of their stock fan in place. Could the fan be warped? Idle never tampered with
K
ki11er13
Louisiana
Apr 13, 2007
  • Apr 13, 2007
how come you took your electric fan off?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Apr 13, 2007
  • Apr 13, 2007
OMG I've never seen anyone with so many cooling issues...
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
It's not just cooling issues... It's me. My life is being punished. I must have had a grandfather who was a Slave owning pron producer who worshipped satan and led his own cult to suicide
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
Could it be that the fan is warped?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Apr 13, 2007
  • Apr 13, 2007
That's just bizarre, dude. Even if the fan clutch was seized, it wouldn't be giving you that kind of a problem.
Only thing I can imagine is that the fan might somehow POSSIBLY be on backwards. That's the only thing left, really, because the only variable is two parts - the fan and clutch - and by swapping the fan clutch out for the old one, you pretty much eliminated that as being the problem.
Maybe your car's mad at you for taking away its e-fan, and it's demanding something nicer and more expensive...?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
Bizarre is right. The only thing I can think of is that the problem was just not presenting itself for whatever reason when I ran the car without the fan. So I went to the local performance store and bought a better temp controller... Thicker wires, 30 amp fuse and I'll put the fawkin e-fan back on. Dwain the radiator again and take it back out to put the efan back on.
I swear to god if one more thing goes wrong with my cooling system I'm selling both mustangs and getting an Impreza STI.
HISSIN50
34
129
Apr 13, 2007
  • Apr 13, 2007
Does your water pump have any issue spinning? Is there some sort of interference issue (something hitting something)?
That's about the only reason I can think why there'd be an issue. I agree with DW77 that even if the clutch was fully locked, it should be alright (unless the fan blade is not able to spin).
Oh, should you swap cars in, consider a VW or some other air/oil cooled variant.
Good luck.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Apr 13, 2007
  • Apr 13, 2007
if the fan was warped, it would shake the piss out of the car, like it had a bad motor mount, really bad vibration. if it was seized it wouldnt do anything but turn faster and when you hit the gas it would sound like a blower like a leaf blower. I dont know what the h it is.
G
getusummm
156
#10
  • Apr 14, 2007
  • #10
Do you have an exposed air filter under the hood? If so, when you throw the stock fan on, you will get turbulent air wash which will throw the MAF sensor out of wack.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 16, 2007
#11
  • Apr 16, 2007
  • #11
So I confirmed it is happening only when the fan is mounted. So I bought a flex fan... SAME PROBLEM lol just not as bad. Still wants to cut out. All of the pulleys look fine when running
Whoa- That makes sense. Yes, yes I do. I'll check into that, I still have the stock air box. I'm running a short CAI and a cone K&N filter with a C&L 76mm MAF.
W
E
I
R
D
G
getusummm
156
#12
  • Apr 16, 2007
  • #12
Its not wierd at all. Its very commom with open underhood filters. You should either put the stock air box back on, or move the filter into the fender. Been there, done that.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 16, 2007
#13
  • Apr 16, 2007
  • #13
Dude you don't know how much I appreciate it. I'll try that and see if it remedies my problem. And that would make total sense being that when I take the fan off there is no more turbulent air
I hope this works.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 17, 2007
#14
  • Apr 17, 2007
  • #14
Thanx getusummm!!!
I would have NEVER figured this one out. I put a piece of cardboard in between the filter and the fan... Low and behold the idle smoothed out!
G
getusummm
156
#15
  • Apr 17, 2007
  • #15
Thats all those dang underhood filters are good for. Poor idle and surging. I have seen people just build a shield around them and even that helps out. Anything just to block the fan wash.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 17, 2007
#16
  • Apr 17, 2007
  • #16
Yep... I lack a K&N filter and a 4" coupler in having my stock air box back together.
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Apr 17, 2007
#17
  • Apr 17, 2007
  • #17
or just move the filter to inside the fender?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 18, 2007
#18
  • Apr 18, 2007
  • #18
Well I meant 3.5"
My buddy said the same thing, but it's annoying to take the wheel off the car, then pull the inner fender gunk out, then the filter get's rained on etc...
I put the stock airbox back on and don't even notice a difference. No air baffle plus a K&N filter on a stock mustang is worth a dyno'd 7-10 hp. The "Cold Air Intake" doesn't add any more.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Apr 18, 2007
#19
  • Apr 18, 2007
  • #19
I guess that explains part of why I had no luck at all when I bolted on a cone filter to my notch awhile back on a whim. But even with it mounted in the fender, I still got pinging, a loss of power, and just a tiny, tiny bit of surging - maybe that whole thing about the curve before the MAF, I dunno...
I'm happy with the stock box and paper panel filter. I can't quite justify a K&N as of yet - I don't see that I'd be gaining anything on a stock H/C/I motor at all, as I don't draw THAT much air through the intake to a point that the paper filter is a true restriction. Plus the oil migrating to the MAF wires from a K&N would only add another headache to my already long list of annoyances...
So, Strype, are you gonna bolt up a different e-fan configuration later on?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 18, 2007
#20
  • Apr 18, 2007
  • #20
It'll probably be used as a door stop or for target practice.
1 of 2 Next Last
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
