Fan Clutch Question
miksax
48
Hey Guys-
I think my fan clutch is dying--my fan spins after I shut my car off. The car doesn't run hot (yet) but I ordered a new fan clutch and fan. I didn't see an explanation in the Haynes Book, so I'm kinda in the dark on the job. Is there any tricks, secrets, or tips for the job? Any advice would be great, thanks!
Mike
Takes an 8mm socket for the top two fan shroud bolts (or maybe it was 10mm?), a 10mm box-end wrench for the pulley bolts, and a big ol' honkin' Crescent wrench for the fan clutch. Use the 10mm wrench as a back-up while breaking loose the fan clutch, and leave the belt on until you've got all four pulley bolts loose - leaves tension on so it won't slip outta your grasp as easily.
A good fan clutch should allow you to be able to turn the fan by hand while the motor's off and cool, but there should be a sufficient amount of drag on it - when it's warmed up and switched off, it should be more difficult to turn by hand (as long as you've got a thermal fan clutch). If it just freewheels and spins like a top with the motor off, it's probably shot.
Yep. Did you get a plastic replacement fan blade or metal? If you live in a hot climate and got a metal replacement, it should do you very well.
When you remove your old one, if you see silicone fluid leaking out of the hub, that indicates it had seen better days.
Good luck.
