Fan clutch... ?
Mysterio
101
Lakewood, Ohio
I bought a new fan clutch to put on since my car starts to heat up when idling but stays normal when driving... I'm looking at the car and it doesn't seem like the fan clutch even belongs on there.. How does this thing go on?
I had to remove the fan shroud at the same time as the clutch/fan assembly (I held the fan and clutch inside the shroud).
Good luck.
the fan clutch sits inside of the fan, and the shaft connects to the pulley and the pulley connects to the water pump. The newer fan clutches make the holes slotted so its easier to line up, which is a big difference from my expierence.
