  • 1994 - 1995 Specific Tech
Fan Not operating, overheating problem
  • Thread starter Thread starter johnnydeebee
  • Start date Start date Aug 2, 2004
J
johnnydeebee
San Jose, CA
Aug 2, 2004
  • Aug 2, 2004
95 GT Had the recall done & circuit breaker installed. Fan still shuts down and engine overheating now...Any other ideas out there...
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Aug 2, 2004
  • Aug 2, 2004
there's your answer right there.. take that bitch out!. My car did the same thing, pulled that out and works fine. Give it a shot.
BlackVert
5,589
9
98
Bethesda, MD
Aug 2, 2004
  • Aug 2, 2004
if the breaker keeps tripping, it probably means your fan is going. mine just went and luckily the recall had not been done yet, because they gave me a new fan.
other than that, i suspect the fan motor is going bad. you could try hooking the battery straight to the fan just to see if it turns.
94TURBO5 O
2,509
VA
Aug 2, 2004
  • Aug 2, 2004
Just tap into the #17 pin and ground it to a toggle switch and run high speed manually. The directions are in the FAQ.
squall9393
534
Oceanside, CA
Aug 3, 2004
  • Aug 3, 2004
My fan just died so I installed a Flex-a-Lite. Not much work, just a little ingenuity. Haven't figured out how to wire it into the ignition to get it to turn off when the car shuts off yet though. Geez, this baby is spinning well. Fan spins so fast that when I shut the car off people still think the engine is running. I give the fan 2 thumbs up.
94TURBO5 O
2,509
VA
Aug 3, 2004
  • Aug 3, 2004
Got pics?
squall9393
534
Oceanside, CA
Aug 4, 2004
  • Aug 4, 2004
94SC50 said:
Got pics?
Not at the moment but once I get em I'll start a new thread with the process and the results.
G
Green_Meanie
161
  • Aug 4, 2004
Mine is hooked into a 30 amp fuse in the passenger compartment fuse box. If I forget to turn off the switch, the ignition kills it when shut off.
squall9393
534
Oceanside, CA
Aug 4, 2004
  • Aug 4, 2004
Good idea. I never installed a cut off switch though. The fan has only drained the battery once after turning the engine off, but it was really freakin hot and I had been running it in traffic with the A/C going before then so obviously it took it a while to cool the engine down to where the fan would shut off. Thanks for the idea. I orginally put it where the old fan fuse was in engine fuse box but that was on constant power instead of switched.
Jarrod
bjl95mustang
1,495
Austin,TX
Aug 4, 2004
#10
  • Aug 4, 2004
  • #10
I just went and got a oem replacment fan motor from auto zone for $60. It was a siemens s/p brand motor and I think with a lifetime waranty.
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
#11
  • Aug 4, 2004
  • #11
yeah, but it's complicated as hell. the directions need to be done over and simpler
J
jasonlee0704
219
Kansas City, MO
Aug 4, 2004
#12
  • Aug 4, 2004
  • #12
The recall work (which I had done myself, too) does not fix the fan.
What it does is shut the fan off when it malfunctions, to prevent an engine fire.
You're still left with a non-working fan (great job, Ford!) - I'd get it replaced, instead of just bypassing the circuit breaker.
BlackVert
5,589
9
98
Bethesda, MD
Aug 5, 2004
#13
  • Aug 5, 2004
  • #13
if the fan is dead when the recall work is done, they will replace the fan at the same time. the recall specifically says that and that is what happened for me since the fan was dead when i brought it in. here is the recall:
http://www.recalldata.org/1995/3351.shtml
if you do have to replace the motor, be careful removing the old motor, it is a pain getting the fan blade off.
95snoozer
2,572
RCR
Aug 5, 2004
#14
  • Aug 5, 2004
  • #14
i need to hard wire my fan.....
i guess this question is for those who have done an aftermarket fan. can i cut the power and run the high and low off the batterry directly with just a toggle switch and relays to run the high speed and low speed completely manual even with the car off. I wont walk off and leave the fan on.
isnt this close to what is done for the A9L swap
slvrbullit302
986
Alabama
Aug 5, 2004
#15
  • Aug 5, 2004
  • #15
Three months after I had the recall done on mine, the fan still locked up and I ended up having to replace the wiring from the CCRM to the fan. Ford would not cover the work.
Anyways when I installed the Fluidyne I also installed a helper fan/ track cool down fan. See pic below.....
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
