  • SN95 4.6L Mustang Tech
Fasteners
  • Thread starter Thread starter ukgtguy
  • Start date Start date Mar 5, 2007
U
ukgtguy
North-East England
Mar 5, 2007
  • Mar 5, 2007
I'm finally going to be starting a bunch of work to mod my GT (brakes, suspension etc) and I was thinking of stocking up on some nuts and bolts etc to replace any fasteners which are past their prime as I reinstall stuff.
What I need to know is on the SN95b (2004) are the fasteners all metric these days or still UNF (or a mix). Also - I expect to come across nylon locking nuts which will really need replacing; but are there any one-shot 'prevailing torque' type fasteners which have to be replaced once they're removed ?
I noticed in the factory service manual for example that if you remove the bolts securing the lower control arm to the rear axle it says (as it does in a lot of other cases) to 'discard the bolt'.
Thanks.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 5, 2007
  • Mar 5, 2007
Involving the brakes, the only TTY (torque to yield) bolts that I know of are the anchor plate bolts. Once you remove them you should throw them away and replace them with new bolts. The caliper bolts can be re-used.
Anchor bolts are 85 lb-ft.
Caliper bolts are 23 lb-ft.
There are quite a few TTY bolts used in the suspension/chassis. The LCA's are one of them. Which specific suspension components were you thinking of replacing?
U
ukgtguy
North-East England
Mar 5, 2007
  • Mar 5, 2007
Hi. Thanks for the feedback.
I'm only swapping out the springs and front brakes initially - but I was going to drop the control arms (or axle) to do the spring install without compressors.
I'll assume any bolts that the Ford service manual says to discard are TTY then.
Is it best to replace the TTY fasteners with new TTY fasteners, or are new bolts with nyloks sufficient ? (I don't want to take any chances here !)
I'm guessing from the stamps on the fasteners I checked so far they're actually metric rather than UNF ??
Cheers.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 6, 2007
  • Mar 6, 2007
Yes, it will be fine to replace the TTY bolts with a regular Grade 5 bolt and Nylock nut.
There should be some numbers stamped on the bolt head, if so they are metric.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 6, 2007
  • Mar 6, 2007
i would only use Grade 8.8 or 10.9 on a suspension. any bolt that doesnt have a nylok, or cotter pin should have safety wire on it.
twogts4us
4,188
12
79
Dunedin, FL
Mar 6, 2007
  • Mar 6, 2007
You sure about that (LCA bolts being TTY)? I know a lot of instructions tell you to buy new ones, but many have told me they've reused em. I myself have reused em too. The only TTYs I was certain of were the head bolts...probably some other engine bolts too.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 6, 2007
  • Mar 6, 2007
they are TTY if the torque sequense involves turning them an additional amount of degrees after reaching a lb-ft or Nm spec. true fasteners should be replaced, however finding the correct ones is usually a challenge.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 6, 2007
  • Mar 6, 2007
Positive.
A Grade 8 bolt for the LCA's would be WAY overkill. A Grade 8 bolt for the LCA's would have over a 100,00 PSI load strength. Even with a 1000 HP motor, you would never even come remotely close to breaking a Grade 5 bolt. Even a Grade 5 is a little overkill, but it's good insurance. There is no such thing as a Grade 8.8 or 10.9 bolt. There is however a 8.8 and 10.9 class rating. Those are a totally different median steel bolt. Median steel bolts are much heavier and softer than a carbon steel Grade 5 or 8 bolt, and it wouldn't be a good idea to use them for suspension bolts.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 6, 2007
  • Mar 6, 2007
i was mearly pointing out that metric bolts have 8.8 and 10.9 ratings and do not use the dashes like standard old style bolts use.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 6, 2007
#10
  • Mar 6, 2007
  • #10
I understand you were just trying to help, but you were recommending a bolt that is softer and has a significantly less load strength than even a Grade 5 bolt. I was just clarifying for our friend across the pond.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 6, 2007
#11
  • Mar 6, 2007
  • #11
ahh just realised he was in the country that ran my ancestors out of ireland. (no offense, my family were extremely active in the IRA).
i know that Sean Hyland used to list all of the bolts on his webpage. he is expensive, but it might be worth shooting an email to them to see if he still has them or can give you Ford part numbers. usually if you can go to a Ford dealer with part numbers they can get it even in a different country. i know BMW dealers can get German model specific parts. i havent tried scoring some Australian heads for the mod motor, but its worth a try.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
