Fastest stock sn95 5.0 shootout
After reading the new Car craft and reading some guy went 13.08 with basically a stock notchback fox i got to thinking what is the fastest someone has gone in a stock sn. Here are the rules: Can have longtubes,CAI, Slicks and skinnies, pulleys, and timing advance. No weight reduction. What do think someone could run if they had all these things and a manual, launching off the rev limiter? Please no comments about breakage because as the saying goes: Race it to break it, fix it to race it.
Purestock went 13.9 COMPLETELY stock in his '94 on street tires. He did remove the serp. belt and air silencer. This was also done at my home track that is a SOLID 2 tenths and 2mph slower than many others I frequent.
My blower is sitting in a box in my garage, alogn with the LT's, so I dont think they have yet helped my 1/4 times. :D
That 13.8 is with the 3.73's, crappy no-name h-pipe with weld-in flowmasters, blaster coil, 13* timing, crappy ebay cai, disconnected front swaybar, drag struts in front set to really soft, and a 1.85 60' on bfg drag radials on stock wheels.
Like I said I bet with a set of 10.5" wide et streets, a redline launch, and a prayer to god that my clutch, rear end, and tranny help up I could get at least a 13.5, but at the same 99.5mph. :nice:
I plan on getting et radials, but not sure if I'll ever make it down to the track again before putting on the blower.
Edit: and paul how much is removing the serp belt worth? Dont you run a risk of running really hot at the top end since the water pump isnt moving? Also on the same subject, how does one run a short belt? Any routing diagrams you guys have?
WELL AT LEAST YOU CAN LOOK AND SNIFF IT ONCE AND A WHILE, MY KIDDS THINK I'M CRAZY BECAUSE I SNIFF THEM. THEY DON'T UNDERSTAND THAT THEY ARE 347S 306S BLOWERS AND TURBOS I ALWAYS HAVE TO BUY THIS BUY THAT WHEN IS IT GOING TO BE MY TURN! TELL ME WHEN
It took me a long time too. I had to start a new savings account and have $175 a month automatically deposit from my check. Then a year and a half later I had the money to buy the blower and didnt have to go broke to afford it.
I've had my 94 since summer of 01, and i havent done any real mods to it other than gears, wheels, and suspension, and all of those I did because i put it in a pond and had to replace stuff anyways.
Do gears count???
I went 13.56 @101 with my 95 gt. 5 speed
Mods
full mac exhaust
pulleys
diablo chip
super coil
14^ timing
3:55 gears
245/60 bfg drag radials
big and little welds
no front sway bar
Eibach drag launch kit
90/10 struts
3 way adj. rear shocks
cold air kit.
smog. elim pulley kit.
line lock.
Tremec 3550
spec stage 2 clutch
This was still with full belt running all the pulleys.
Motor totally stock from throttle body to oil pan. except for adj. fpr.
This same setup went 12.31 @ 108 with a 100 shot.
When I first got my car, I had Full MAC Exhaust (shorties, PC, cat-back), Pullies, March Ram Air, all else was stock from TB to rearend. For tires I had 26x10x15 ET Streets.
Times was a 13.58 at 102 with a 1.81 60'.
