fearing the fog!
I bought a standered 96 3.8 stang, it was the basic model and I decided to put on a set of stock fog lights off of the same year. I got them installed and even noticed that the wiring harness was there for the lights already. But when it was time to try them out I turned on the headlight expecting them to come on and nothing happened. Im not sure if there is spose to be a switch that turns them on or what, but I can't figure them out. I looked to make sure there wasn't any blown fuses. If there is anyone that could help me out that would be great.:shrug:
There is a fog light switch as well. It's near the e-brake but on the 3.8L it's replaced by a coin holder. if you pop the coin holder out, you'll more than likely find a plug under it loose. You'll need to get a 94-00 fog light switch and hook it up
Moved to 3.8L tech
Also check that there's a relay in place for them. Since the car didnt come with fogs, you'd think they'd have pocketed the relay to save a couple cents.
