Fel Pro 8548-PT2: thicker than stock?
  • Thread starter Thread starter jaymac
  • Start date Start date Jul 15, 2005
jaymac
995
Northern Mass
Jul 15, 2005
  • Jul 15, 2005
I'm trying to line up a contingency plan in case I need more p/v clearance when I put my heads on (milled ~.030"). I can't find the 9333pt1's or 8548sp1's in stock in a store near me (yet).
SO, does anyone know for sure if the 8548PT2's are indeed thicker than stock, and if so, how much?
Thanks!
J
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jul 15, 2005
  • Jul 15, 2005
The 8548-PT2 and PT1 are both supposed to compress to .050 when torqued down to spec. I dont know if this helps but gives you something to calculate with.
jaymac
995
Northern Mass
Jul 15, 2005
  • Jul 15, 2005
Well I found out the ones I already bought are 8548's, and Tmoss said 9333's are thicker than stock, so if they both compress to .050, then I "should" be alright. Thanks Pete!
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
G
1983 GLX Convertible 5.0 5-Speed 4BBL 'Barn Find' - 82,000 original miles - Restoration Motivation Needed
  • Grande Luxe X-Factor
  • Oct 7, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2024
Mac131
