Fender Replacement
  • Thread starter Thread starter stangracer85
  • Start date Start date Oct 24, 2005
stangracer85
12
Colorado Springs, Colorado
Oct 24, 2005
  • Oct 24, 2005
Has Anyone Removed And Replaced A Passenger Side Fender On There Mustang Before. Mine Is A 85. I Have One But Wandering On Any Tips Before I Jump Into The Project..curious Is Is Hard And Time Consuming Or Is Pretty Straight Forward?!
bt15
129
Oahu
Oct 24, 2005
  • Oct 24, 2005
It's a pretty straight forward proposition. The biggest "gotchas" are:
1) The little screws that attach the plastic inside fender wells
2) The hidden screws up in the polyurethane attachment points for the front bumper (sometimes rather corroded, and quite well hidden)
3) The vacuum lines and vauum reservoir cannister (plastic) that attaches inside the fender
4) The possibility of dinging the front edge of your door with an extension as you try to access the bolts through the door jamb opening
5) The often corroded bolt that attaches the bottom rear portion of the fender to the rocker panel (under the door hinges)
It's not particularly daunting, just don't become impatient and accidentally damage one of your attachment points, or a carriage bolt receiver while working through your project.
Good luck,
BT
stangracer85
12
Oct 24, 2005
  • Oct 24, 2005
thats the kind of info i was looking for...i was just looking at bolts by the door jam and inside the fender...i think ill take a stab at it tomorrow when i know ill have more daylight.
stangracer85
12
Oct 25, 2005
  • Oct 25, 2005
Does The Pass Tire Need To Come Off Vehicle To Replace The Fender Or Can I Do The Swap With The Tire Still On The Vehicle??
bt15
129
Oahu
Oct 25, 2005
  • Oct 25, 2005
You can do it with the wheel on, but it's much easier with it off. You can then access the screws holding the inner fenderwell splash shields much more easily, and you're not as cramped when reaching up inside of the front of the fender where it attaches to the bumper cover to remove the nuts there.
stangracer85
12
Oct 25, 2005
  • Oct 25, 2005
How Long Do You Think It Normally Takes For The Average Guy?
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Oct 25, 2005
  • Oct 25, 2005
I usually just hold the door about halfway open with my leg and run the ratchet extension while standing in of the door. I never had a problem, but cant be too safe. Everything else said was right on par though.
If you bolts arent too badly rusted, it should take 20 mins on the car is setup (alot of the time is in the nuts holding the nose to the fender, but if those arent bad your set. I use a flathead ratchet for most of those and its a breeze. The first time is the hardest with a fender, should oyu ever have to do it again its a breeze.
stangracer85
12
Oct 25, 2005
  • Oct 25, 2005
That Is Some Good Advice..i Appreciate It All. I Just Dont Want This Project To Become A Nightmare Thats All. Get Half Way Done And Then Not Be Able To Finish It The Same Time. Hate It When I Have To Leave Something Not Finished Just To Come Back And Finish It Later.
stangracer85
12
Oct 28, 2005
  • Oct 28, 2005
i got the fender all swaped out last night...wasnt that bad at all. thanks for your guys help and advice.
dkins419
187
Michigan
Oct 28, 2005
#10
  • Oct 28, 2005
  • #10
stangracer 85, how long did it take you to swap out the fender?
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
WTB Oxford white hood, bumper and fender for LX foxbody
  • keel
  • Jan 7, 2026
  • Want to Buy
Want to Buy Jan 7, 2026
keel
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
How do we feel about first gen fuel caps?
  • Teen'93stang5.0
  • Apr 25, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All May 3, 2026
General karthief
