Few EFI to Carb Questions...
  • Thread starter Thread starter Wasim05
  • Start date Start date Jul 26, 2004
Wasim05
273
Pflugerville, TX
Jul 26, 2004
  • Jul 26, 2004
so decision is made, im 100% im going carb'd. anyways, selling the harness to a fellow member. question is, will my gauges still work, i plan on going aftermarket oil press/water temp gauges later, but for now will they work. arent there 2 harnesses, one for engine (maf, etc) and the other electrical (gauges, lights, etc)??? also, I know I need a different distributor/coil... a non-tfi right? also, i know i can use a stock efi fuel pump as long as i use a inline regulator to turn the psi down to say 3-5psi instead of ~40psi? But who makes one? and where can i get it? and how much bigger of fuel lines do i need? I would like t go braided steel, but thats $$$.. if not, what size? and where can i get them from? also, 1 more question, what about the throttle cable? is there some sort of bracket i can bolt it to and where can i get it from? also, 1 more question, what about the throttle cable? is there some sort of bracket i can bolt it to and where can i get it from?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 26, 2004
  • Jul 26, 2004
You won't need bigger fuel lines until you start pushing over 300HP. I just got an inline Holley fuel pump used for $40 CAD (around 28 bucks for you USA folks). I removed the stock pump and replaced it with a pickup tube, right into the rubber hose that was over the in-tank pump. I used the bigger stock "feed" line and removed the smaller "return" line. All you need is 6psi.
I "think" the guage wires come from the computer harness but I'm not sure, I took the car apart last year and can't seem to remember. But you may be right, the harness from the driver side has all the oil and temp guage wires??? I just went ahead and got the guages right away. BTW volts still works with all the wires pulled out from under the hood lol
I got a throttle cable and bracket from a 1985 3.8L V6 Cougar. I machined the bracket and made my own support for it to work with the damn air gap intake which seats the carb pretty high. You can just buy a bracket that will bolt the carb studs and be done with it but it was pretty expensive IMO.
I guess you know about the distributer and ignition upgrades that need to be done?
pocket3799
286
Albany,GA
Jul 26, 2004
  • Jul 26, 2004
Check out this page: http://www.jason.fletcher.net/tech/efi-carb/efi-carb.htm
dastang2
2,020
tx
Jul 26, 2004
  • Jul 26, 2004
if you are going to use the stock efi pump and an inline fuel regulator, DO NOT get just a regular "dead head" regulator. get one that has a return port on it. otherwise, you are cutting 40 psi down to 6 and your pump and regulator may be damaged. if i was you i would do the HEI ignition swap. it is easy and you don't have a big module to put under the hood, like duraspark. i have the info so i can send it to you.
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
