few ?s about my 5spd swap
blckstng96
208
im wondering if anyone knows the bolt dimesnions for the hardware that bolts the clutch setup to the flywheel or where i may be able to get them.2nd is do i need the plate that goes between the trans and the block because i dont have one.looks like its just a dust shield to me but idk.and 3rd is how can i wire my reverse lights in without getting some sort of new wiring harness.im trying to do this on a budget so im trying to figure out what wires on the auto harness near the trans will let me wire up the reverse lights
Your best bet is to get a donor car or hit up a salvage yard.
The reverse llights work off a two post switch on the trans. you could always hardwire it right to the trail lights. But there is a stick harness you could replace it.
You need the dust shield. The auto has a two peice shield. The bottom comes off to get the toruq conveter bolts. The stick has a one peice. Same thing early 80's to 95.
The bolts for the PP and flywheel. Can't help you there man. I think mine were only like 10mm bolts. from pp to flywheel.
