Few tips please?
just got a 94 GT. It seems to need a little work. It runs good. Did a tune up, cap, rotor, wires, and plugs. It seems to have a hesitation. I have had fox body 5.0's but never a sn-95. Are the cleaning of the sensors the same? Also it has red top injectors in it. I think they are too big. Cobra intake, forged pistons, and I beam rods, some kind of after market cam, gt40 iron heads, roller rockers, intake, headers, msd coil and dizzy. 5-speed. How do you pull the codes?
Injectors are fine, as long as the meter is calibrated, of course.
Clean all your sensors. Check your timing. Maybe a new fuel filter. Have you check your coil? If it's not missing, just hesitating a lil bit, more than likely it's a dirty sensor. MAF, IAC, ACT, IAT, TPS, check those out.
The plug to ck the codes is by the a/c cansiter on the passenger side firewall. The connection is just hanging around in that area.
MAF cleaning
Clean the IAT while you're at it (unlike a fox III, it's in the air intake tubing. It takes 30 seconds to remove, clean and reinstall).
Another vote to check codes and check timing.
You might be seeing early signs of a PIP on the way out as well.
Good luck.
