  • 1994 - 1995 Specific Tech
FI Q? running rich
  • Thread starter Thread starter fords2fast4u
  • Start date Start date Apr 12, 2005
fords2fast4u
1,426
Mission Viejo, CA
Apr 12, 2005
  • Apr 12, 2005
So, since my oil cooler decided to come off the block and I rebuilt the engine and put a cam in it that was way to big... the car has not run right. I changed many things when i took it apart (big cam, AFPR, 30lb injectors, ProM, different chip (for the 30s), all in prep for the blower)
The lift on the cam with 1.7 RR's was like .533/.566 with a high duration. Well obviously because the stock GT-40s couldn't take that much lift, it lost a lot of power and I’ve been trying to get it back ever since. The car also runs hella rich.. Like going So, since my oil cooler decided to come off the block and I rebuilt the engine and put a cam in it that was way to big... the car has not run right. I changed many things when I took it apart (big cam, AFPR, 30lb injectors, ProM, different chip (for the 30s), all in prep for the blower)
The lift on the cam with 1.7 RR's was like .533/.566 with a high duration. Well obviously because the stock GT-40s couldn't take that much lift, it lost a lot of power and I’ve been trying to get it back ever since. The car also runs hella rich.. like going from 17 mpg to 8. Last week I changed the 1.7s to some standard 1.6s and that helped a lot, but it was still running rich. I changed the fuel injectors today back to 24s with a new calibration tube for my C&L, and put in the original chip that was burnt for the 24s.
Now, with a lift of .505/.533 and a duration of like 282/284, it still runs rich as hell. I know the plugs are probably fouled.. but it does run quieter for some odd reason. It gets up, but runs like crap and about as fast as a stock GT or something... timing is at 10 degrees and fuel pressure at 47 lbs i think.
this weekend I’ll be putting in my TFS stage 1 (.498/.510) but if that doesn't help, i am at a loss.
Any ideas? from 17 mpg to 8. Last week I changed the 1.7s to some standard 1.6s and that helped a lot, but it was still running rich. I changed the fuel injectors today back to 24s with a new calibration tube for my C&L, and put in the original chip that was burnt for the 24s.
this weekend I’ll be putting in my TFS stage 1 (.498/.510) but if that doesn't help, I am at a loss.
Any ideas?
fords2fast4u
1,426
Mission Viejo, CA
Apr 13, 2005
  • Apr 13, 2005
was my question too long and detailed?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Apr 13, 2005
  • Apr 13, 2005
Nah, but I think we know what your situation is, since you clarified it so well. (More than once). J/K I think you will notice a huge difference once you get that TFS Stage 1 in there. Other than that, I don't know what to tell you....
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
94 cobra possible idle issue?
  • Bowen94
  • Feb 15, 2024
2K
1994 - 1995 Specific Tech Feb 16, 2024
93 running pig rich black plugs
  • Mstng93SSP
  • Aug 28, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2023
Monkeybutt2000
M
