Forced Induction Finally Blew Turbo Header Gasket
Only took about 300 miles, but blew the drivers side header gasket yesterday. Going to forgo the gasket this time and try the copper rtv trick. Any tips on how to install so that it will last?
I rough up of the head and the header flange a little bit with an emery cloth to give the RTV something to bite into. I let it dry at least 24 hours before use.
Sent from my XT907 using Tapatalk 2
That's how my Headers were don't RTV there on over a yr 14 psi..seems fine no leaks.i do have a small leak by the downpipe..i contribute that to the bad band clamps which I want to replace with RPS clamps...
For the aluminum heads they recommend the 1" long bolts, that is what I run in mine. I don't see a part number for the 1" long in a pack of 16 (damn chevy guys get catered to I swear...) I'll call Booth over at Proform today and see if they have a part number for us ford guys. I know they didn't when they first gave them to me to try but hopefully they stepped up the ford love
Switch to studs.
As mentioned before, I rough up both surfaces. I put a small coat on both the head and manifold, then tighten just hand tight until it begins to squish out the sides. I wait a half hour or so until it's no longer tacky to the touch and then torque to spec.
