I finally got my baby back and almost forgot how to drive it. The mods that were just completed:
Vortec V-2 S-Trim
Tremec TKO II Transmission
Subframe connectors
LCA's
Fuel Pressure and Boost guages (replaced the clock)
Aluminum Driveshaft
Yoke and Bell Housing
Anderson Power Pipe
Obviously computer chip.
New dual friction clutch
The car is completely different and a lot faster!!! Obviously... My questions are:
1. TKO II trans. sits differently in the shifter box than the stock trans. It seems to be higher and to the right. I have to lean a little bit to make the shifts. Does this sound right? It also knocks against something when engine breaking in all gears. It almost sounds like the driveshaft is tapping against something as the torque shakes the trans. Sound right?
2. Now that all this work is completed, I have to drive it 500 miles to break the clutch in. So, he tuned it very conservitavely and without a dyno. So, the idle is all over the place, revving itself up and down and actually stalling sometimes. Any ideas?
Vortec V-2 S-Trim
Subframe connectors
LCA's
Aluminum Driveshaft
Anderson Power Pipe
