Finally decided to break down and buy a new cam, recommendations?
Great68
691
Victoria BC
I decided out with the old, and in with something that I know the specs on and will be compatible with my new parts and what I want the car for.
Any recommendations? My mods are in the sig. I use my car 99% for the street, and would rarely take it to the track. I would like something that works with a stock or mild stall converter and 2.80-3.25 gears (no higher numerically than 3.25).
Thanks,
Bryan
How does the 266 work with a high rear ratio and stock converter?
I can't find specs on it on the comp website, it goes from xe262 to xe268.
All I need is a confirmation that it will work, and I will buy a 266.
The 266 cam might be for a hydraulic roller, but im sure you can order it as a non roller setup. The specs are aggressive, but not TOO aggressive in anyway. It will work fine with the rear gears and stock converter. If you cant get that cam in a non roller version, I would definetly go with the 268. I can see you freeing up 30+ hp with this cam swap. You will feel a seat in your pants difference in power!
