  • SN95 4.6L Mustang Tech
Finally pulling off my LT Headers
  • Thread starter Thread starter VSTOLsnake
  • Start date Start date May 24, 2005
V
VSTOLsnake
  • May 24, 2005
Well after 1 year, (3) 02 sensors, 2 MILS (I didn't need) I am pulling off my LT Headers and catted X-pipe because of the P0133/P0153 code. No leaks, no bad wires, 02's are good, out of ideas. After hearing of about 100 people with the same problem, I'm going back to stock. Anyone have any luck fixing this...alot of people say they fixed it but never report back that thier "fix" didnt work.
Thanks
V
VividDreams
200
Lebanon County, PA
May 24, 2005
  • May 24, 2005
What do those codes mean?
If you're selling them I may be interested, ill decide after i know what the code means.
crew_dawg16
445
DeKalb, IL
May 24, 2005
  • May 24, 2005
I am assuming it is to do with the O2 sensors throwing codes.
Did you try wrapping your headers? Are they ceramic coated?
V
VSTOLsnake
  • May 26, 2005
The codes are for the front 02 sensors. Because the LT headers move the 02's back about a foot from the original OEM position, the EEC throws a code because the 02 doesn't respond at the predetermined rate. I have not wrapped them...but I live in Southern Arizona and it was 109 degrees today and I still threw the code so I dont think cold pipes is to blame. Thanks for the help.
EDGE Motorsport
561
Saleen S281, London, UK
May 26, 2005
  • May 26, 2005
can you have the o2 sensor boss moved further up the tubes ?
EDGE
jstreet0204
939
Winston Salem, NC
May 26, 2005
  • May 26, 2005
If your headers are not coated, I think you may still benefit from wrapping the collectors. even at 109 outside, the o2's need to be in the 450 degree range. It could also be a small exhaust leak that yo haven't found. I had a tiny hole in my egr tube where it was creased that threw the same codes. If not leaks and you don't want to use header wrap, then the only other way is to have the pulse delay lengthened with a tune.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
A
Got it running!! (Gt40p top end swap with Mac LT headers and n41 cam)
  • Angelq1028
  • Jan 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2025
AeroCoupe
W
Help! Im at my wits end!!! 2003 Mustang GT recurring P0133 and P0153
  • Warhorse85
  • Jun 17, 2023
  • 2 3
7K
SN95 4.6L Mustang Tech Aug 16, 2025
Warhorse85
W
