Finally rear axle being attended too
aztecgwynn
120
23
28
48
So I just need platform to rant or bitch about this. But finally took car 93 Ford LX Hatchback to get rear end differential looked at.
I knew rear end was toast I can hear howl on left turns on freeways and clucking every so often. But took here to differential shop here in Mesa Az. But again I knew it was hurt but not this damaged but was also aware that this rear end gear was not factory as well because it was quick off line.
So just got off phone with lady from diff shop, so far she said carrier bearings had spun, axle bearing had spun, diff gears are bad, so basically all had gone to poop.
Well estimate new 3.55 gears, new bearings, new axles, new trac loc, $2300.
The crappy part of this I have been asking for good diff places here and nothing no recommendations instead I went to the place I really didnt want to go to because everyone told me this shop expensive now I’m stuck and have to deal with it.
  • Sponsors(?)
revhead347
Just rub Vaseline all over
8,380
1,201
214
40
Acworth, GA
Your sentence structure, capitalization, and punctuation make your post just a little hard to read. I just finished my build progress thread a few minutes ago.
This is what $3k gets you; it's a 1200hp axle. A foxbody axle is way cheaper. $2300 to fix a factory axle is out of this world recockulous. Don't even consider paying that. Tell them you want a used axle off of car-part.com at the very least. You can have Moser build you an all new custom M88 axle that is perfectly straight, any gear ratio you want, any differential you want, and forged alloy shafts for that price.
Kurt
  • Agree
Reactions: General karthief
aztecgwynn
120
23
28
48
Kurt thanks for response but I’m not close to Phoenix let alone someone to pick me up from Phoenix to take me home And find a shop to better suite my needs or my wallet. But this is the only diff shop in east valley so I’m kinda screwed up to this point and because my 5.0 is my daily driver, but yes it pisses me off that I have to pay the fare.
Went toSummit racing to look at prices and ring and pinion they are charging me are double what Summit racing charging for Ford Performance ring and pinion. Axles from Summit racing charging $210 for pair of axles these cats charging me $174 per axle.
revhead347
8,380
1,201
214
40
Acworth, GA
They are vultures. Standard markup is 40%. Sorry you are in that situation. Get AAA. Takes you 100 miles if you break down and gives you some breathing room to find better options.
Kurt
Rdub6
Mustang Master
Dec 29, 2017
1,587
1,177
123
Long Island, NY
Hell, at that price, I’d be watching the Eric the Car Guy videos on how to rebuild the 8.8 and do it myself. (Which some day I will do). I get it, it’s your daily, so that puts you in more of a predicament. Good luck getting it sorted out..... hopefully at a cheaper price!
Even buying your own parts and giving them to him would save you.... if he’d allow that?
aztecgwynn
120
23
28
48
I did think of that and they said that would be fine. But I need to understand that "my car is taking up their rack and that if I choose that route I need to expedite parts"
It sucks I literally am making myself sick just knowing I am possible paying $174 p/axle and $350 just for ring and pinion and I didn't ask what price for carrier was
revhead347
8,380
1,201
214
40
Acworth, GA
There are so many fricken 28 spline carriers out there it's rediculous. I probably have at least 2 of them in my basement. It's a throw away part you take to the recycling yard. They should have been able to source a used one easily. The local pull a part should have at least 10 of them.
Kurt
aztecgwynn
120
23
28
48
does anyone know what is 4 lug bolt pattern size?
And other thing is I can't find a new ford traction loc carrier my luck
Rdub6
Mustang Master
Dec 29, 2017
1,587
1,177
123
Long Island, NY
4x108mm. or 4x 4 1/4 inches Depending on how they list it.
try eBay for the carrier. There’s some used/ refurbished ones on there.
KRUISR
5 Year Member
Apr 16, 2015
325
113
63
50
Any reputable repair shops in the area? Somewhere with good general mechanics should be able to do this repair. Rebuilding a rear differential (for non race or severe duty) is not rocket science. Getting the parts in a timely fashion will be the challenge.
If you can find an old stock geared mustang rear end in locally, just install it to get you going again. Then as time and finances allow rebuild your existing rear end to whatever performance level you are looking for. Then swap the rear back in (or have a general mechanic shop do it).
When I put 3.73s in my rear, I had my brother who is a certified mechanic help me make sure I didn't miss any steps. It didn't take long to set up. He had previous done about 30-40 sets when he working in a 4x4 custom shop.
Hope it all works out.
Gs87GT
238
77
38
Penn's Woods
There is no way I'd ever pay that ridiculous price. For not much more I could have both differentials on my 2017 Ram 2500 re-geared. As suggested, have them reassemble it broke or put a junkyard rear in it for now and get it the heck out of that shop. Then weigh your options.
CarMichael Angelo
clearly, I’ve got something going on in that hole
6,898
234
62
Birmingham, al
m.imdb.com
They aren’t going to replace the carrier, it doesn’t wear out. They’ll rebuild the t-loc with about 50.00 worth of clutches and shims.
CarMichael Angelo
6,898
234
62
Birmingham, al
m.imdb.com
Sorry,.. just because you got no answer here doesn’t justify going to a shop that you knew was stupid expensive.
If you haven’t authorized that work, i’d tell them not to proceed. As stated, most “ competent” mechanics can rebuild that rear.
you don’t need new axles, you need new axle bearings. you don’t need a new carrier, you need the t-loc rebuilt.
The rapery here should be against the law in the same vein that charging 30+% interest on a loan is. Fck,....at those prices, a FORD dealership would be cheaper.
awing
24
10
Westport, MA
I've seen entire working rear ends for sale under $200 on my local facebook mustang group. An average mechanic should be able to swap it in 2 or 3 hours. I agree $2300 is way too ridiculous.
revhead347
8,380
1,201
214
40
Acworth, GA
Apparently not. Most mechanics are parts changers now. If there is anything wrong with the carrier, it takes a lot less time to order a whole carrier and stick it in there, then rebuild the old one.
Kurt
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,272
9,576
224
Massachusetts
I regularly see fox rear axles for sale for $200-300 on local FB groups. I would just buy one of those and have it swapped in.
$2300 is IRS install territory.
Reactions: Gs87GT
darkfader
Mustang Master
Feb 16, 2017
236
317
83
45
Davis, WV
I’m pretty sure I have carrier and axles out of my ‘93 still in my shop. All working perfectly before being removed for upgrades. I can check Friday when I get home to be sure. I’d let it all go extremely cheap just to get it out of my garage, if you need it.
aztecgwynn
120
23
28
48
darkfader thks for offer. But even though it sucks i didnt have a choice or time to exercise options that differential shop gave me.
i dont have the tools, the lift to do work from my home. Now if i was in Ca where parents are now that is complete opposite tools, lift and help to steer me in right direction. Thks to everyone for help.
Rdub6
Mustang Master
Dec 29, 2017
1,587
1,177
123
Long Island, NY
Good Luck man. I really hope they fix it up right for you! Way down the line, and it’s still running right, at least you’ll be able
to say they got it fixed. The money will be long gone, and hopefully you’re moving forward with a lesson learned!
Whether everyone will admit to it or not, we’ve all had our bad experiences/ mistakes. Live and learn!
Thread starter Similar threads Forum Replies Date
69clark Pics. Finally got the cobra rear valance on. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 43
02nightmaregt Rear Finally built!!! 1996 - 2004 SN95 Mustang -General/Talk- 10
fasterthanthem Corbeaus and rear-delete finally in 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
69clark PICS!!! Finally finished the rear bumper project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
NotQuik Got the rear welds on finally...pics 1994 - 1995 Specific Tech 37
S finally installed rear sway bar. Classic Mustang Specific Tech 17
J What final (rear end) gear ratio should I go with? Classic Mustang Specific Tech 24
F 93 LX 5.0 Notch - Finally getting started The Welcome Wagon 1
DemonGT Eibach springs finally installed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
L Finally finishing up the little 83. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
5 Finally decided on wheels 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
DudeStang Progress Thread Finally got my first Fox Body - 1988 GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 501
ncaruso Wheels-Tires Third flat tire in a row - finally ordered a spare tire! 2015+ (S550) Mustang -General/Talk 8
J Electrical finally got my head lights SN95 4.6L Mustang Tech 0
N Thought I had finally finished the rewire of my 65 coupe... Classic Mustang Specific Tech 3
79 Fox Fox Finally got my Fox running! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
R finally sorted 2005 - 2014 S-197 Mustang -General/Talk- 6
1970machwon Engine A couple MAF questions (Finally got my donor engine!) Fox 5.0 Mustang Tech 6
8 Finally Decided to Actually Join StangNet! The Welcome Wagon 2
C 89 GT Vert - Finally cleaned it up and took pics 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RangerJoe Fox New PB, finally got into the 10's! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
John Dirks Jr finally took a drive 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
C Finally got this horse to pass NJ inspection !!! SN95 4.6L Mustang Tech 3
Enzio Lurker finally signed up. The Welcome Wagon 2
B 1997 cobra motor finally toast after 180,000 miles 1996 - 2004 SN95 Mustang -General/Talk- 0
2000xp8 Finally, trans body mounts replacements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G New Mustang owner again (finally)!! The Welcome Wagon 1
bahndrvr Definitely not a new member (joined in 2005), but beyond searching I'll finally be posting:) New to me 1983 4-Eye Notch in my possession now:) The Welcome Wagon 4
Mstng93SSP Finally painted my front bumper 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
TNAVY Finally got a Cobra (my dream car!) The Welcome Wagon 1
R Finally Got to Mustang Week 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
newstang4me New-ish member and Mustang owner (again, finally)!! The Welcome Wagon 1
B Newbie here - finally bought my first Mustang!! The Welcome Wagon 1
BlakeusMaximus Finally lowered my wife’s car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Sketchy_GT Progress Thread Finally!! A Mach 1 1996 - 2004 SN95 Mustang -General/Talk- 7
J Looking at 94 gt for a possible project. Im very happy to get back in the swing of things finally!!! The Welcome Wagon 3
G Paint and Body Spring is finally here and got the car cleaned up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
A Cobra intake finally found and installed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 48
Reddevil91 Progress Thread Maybe I finally fixed this thing 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1159
Mustang Yawie Wow, It’s Been A While But Finally Got A Mustang Back 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
J First Mustang Finally The Welcome Wagon 10
2/75TH RANGER Finally ! Progress On The 302 ! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
FastDriver Finally Got To Drive A '16 Gt 2015+ (S550) Mustang -General/Talk 14
Street Renegade Finally Got Headers And A Tune 2015+ (S550) Mustang -General/Talk 2
0 1990 Mustang Gt Convertible - Kenne Bell - Finally Done! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
GroverDill Progress Thread 1985 Gt I Finally Have A T Top Car. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 383
Ice428 2002 Sonic Boom Gt Finally On The Road The Welcome Wagon 4
James Herbert Finally Joined! The Welcome Wagon 2
jetmech807 Finally Fixed It. 1996 - 2004 SN95 Mustang -General/Talk- 6
C Finally Made An Account The Welcome Wagon 3
