Progress Thread finally tuning (and more)
Noobz,
I understand the interpolation that the ECU does between the lines. However, I have previously verified that my combo idles at roughly 27% air load. Given that fact, on the table you did, can the data in rows 0 and 1 be omitted and thereby opening up entries at other places in the curve to improve the table with actual useable data? Or, is the ECU’s interpolation function good enough that it wouldnt make a difference?
I was thinking maybe an entry at 120% and 140%. Or, other places if you recommend a better strategy. I can pay you for your time if needed.
It is an interpolation like you say.
My recommendation is to run it and pull a data log. We'll let the feedback data tell us where the values need to be changed.
Reactions: JD1964
Man this is awesome, thanks! What a treasure it is to have access to people so willing to share their knowledge and spend their time helping. I hope I can help others in meaningful ways. I'll get busy with this tomorrow and follow up! Thank you thank you and thank you again....
You kidding? He googled that sht!
Seriously, I've seen what he worked with, near genius level and fears nothing, he was copilot when I crashed his toy chopper, didn't flinch, just said like "whoops, not good" :nono:
Reactions: Noobz347
I did 3 different datalogs. These are NA, not boosted (yet).
60 degrees ambient temperature.
1. Startup from cold and idle until warmup.
2. Gentle cruise with a few gentle gearshifts.
3. Full throttle 3rd and most of 4th. (had enough roadway but was gaining on traffic and had to let off before the top of 4th)
trying to upload these .csv files and the forum wont accept them
Just me but if you have not I would do the following:
1) Have the injectors professionally cleaned. I have a set of Lightning 42 lb/hr injectors and they were down to 39 lb/hr and the spray pattern was not good.
2) install a dedicated 12 ga power wire and relay for the fuel pump. Use the old power wire (after the inertia switch) to trigger the new relay.
3) If you can swing it upgrade the fuel lines to 6AN as well as the fuel pump hanger.
This made a difference with my NA 331.
Reactions: JD1964
The injectors I got from a performance service and were claimed to be refurbished and ready and they dont have much time on them.
I like your idea about upgrading the power wire to the pump. (on the list now)
There are a lot of channels that are not recorded in your data logs:
Exact tagDescription in his definition
NRPM
LOADLoad Actual
LOADXLoad%
TPThrottle Position Sensor
TSThrottle Status (CT/PT/WOT)
MPHVehicle Speed Sensor - MPH
SPARKSpark Advance
ACTAir Charge Temp
ECTEngine Coolant Temp
BAPBARO Sensor
VBATBattery Voltage
VMAFMAF in Volts (corrected)
IMAFMAF in Volts (uncorrected)
MAFMAF in Kg/hr
EVPEGR Valve Position—his wideband input
LAMBSE1LAMBSE - PS
LAMBSE2LAMBSE - DS
KAMRF1KAMRF - PS
KAMRF2KAMRF - DS
HEGO1HEGO Sensor - PS
HEGO2HEGO Sensor - DS
PW1Injector Pulsewidth - PS
PW2Injector Pulsewidth - DS
FLAGS1FLAGS1—includes OL, bit 2
FLAGS4FLAGS4—includes DFSO, bit 1
FLAGS10FLAGS10—includes WRMEGO, bit 2
DSDRPMDesired RPM
ISCDTYIdle Speed Control Duty Cycle
ISCFLGIdle Speed Control Flag
AEFUELAccel Enrichment Fuel
EFTRFFTransient Enrichment Fuel
ATMR1Time Since Start
TUNEPOSTune Position
A few specific corrections:
  • Use N, not N_BYTE. The latter stops reporting increases above 4,080 rpm.
  • The MAF entry has inconsistent labeling: its description says kg/hr, but its Units field says lb/min. Preserve the export’s units/header so we interpret it correctly.
NRPM
LOADLoad Actual
LOADXLoad%
SPARKSpark Advance
ACTAir Charge Temp
BAPBARO Sensor
VBATBattery Voltage
MAFMAF in Kg/hr
LAMBSE1LAMBSE - PS
LAMBSE2LAMBSE - DS
KAMRF1KAMRF - PS
KAMRF2KAMRF - DS
DSDRPMDesired RPM
I’ll work on these things, thanks
Reactions: Noobz347
