Progress Thread finally tuning (and more)
I'm just gonna toss this out there because I don't know how critical is is for aluminum heads but...
Those bolts are torque to yield and two different diameter bolts torqued to the same spec, are not even.
I understand. Albeit, the head is already cinched down entirely on its installation prior to all this. It’s not like I removed the stud and the corner of the head lifted. But there’s heat cycles to follow so who knows. If I cinch this down in the ballpark I think it will be fine. That’s with a prayer of course….
The diameter of the washer surface on the bolt was about 1mm bigger than the machined surface on the head. I used a bench grinder to take a little off the bolt washer so it fits. Glad I measured it
I'm looking to see if I can find a 1/2" stud. I could buy an entire kit but I bet with some searching I should be able to find a single comparable fastener.
Anyone think a 1/2" stud would be better than a bolt in this situation?
Honestly, these kits are cheaper than I thought. I'll probably spring for one just to get a fastener I know was made for the job.
Reactions: Noobz347
