Hmm, for an idea man you're not very open minded are you?
Yes, you don't find Granada spindles in "urban" salvage yards. Because they don't BUY Granadas. They are generally in business for late model crash donors. I am not urban and can lay my hands on a set of Granada spindles tomorrow if I needed them. The price I'd have to check. I don't enjoy taking them off myself but a loaded set for $50-60 is a hard deal to resist. Many yards value them at double that or more.
My neighbor would very much like to know where he can get $350 for a "crusher" car. For extra cash he picks up unwanted cars and hauls them to the scrapyard. A complete Granada complete will bring about $125. Less drivetrain more like $100. Being "suburban" but not an idiot he keeps a close eye on scrap metal prices and only bothers with this side job when scrap is high enough to be worth his while. For $350 a car he'd quit his day job.
You don't have to search out out a "national database" to find used parts. We have this thing called the internet. "JunkyardDog.com" is only one example of a listing of salvage yards nationwide. An example of one of the local yards there is "A and R" salvage with almost their complete inventory on line for browsing.
An even simpler solution would be to call a cooperative local yard who is a member of the "Eden" (or other system). Within about three minutes they can locate and price anything available within your preferred shipping distance or nationwide from other yards using the Hollander or FastParts database systems. No weed squatting required.
I don't get this-"Just the modeling cost for modifying a spindle is thousands, not including the hundreds of hours designing them, finding someone to manufacture them, and managing their development and production"
One. Modeling cost? Locate someone who has done the Taurus swap (or God forbid, do it yourself) and find out how far the tie rod joint location needs to be relocated to correct bumpsteer. Redneck dirttrack racers can figure out how to make thier own bumpsteer gauges, it's not hard. Or you can buy them. Then also sort out how much closer to the spindle the tie rod end needs to be moved so the "throw" of the Taurus rack will match the length of the spindle arm so to correct the steering radius problem. If you passed high school geometry this might take all of an afternoon. If you're feeling ambitious, Granada spindles all also have a bit of a scrub radius problem you could look into correcting.
Then the model itself. Butcher a few spindles by cutting up the tie rod arms and weld them back together with the corrections you discovered in your busy afternoon. Make absolutely sure all the dimensions are exactly where you want them and you have a pair of "models". Is welding cast hugely expensive? My brother in law will do it for $40 per spindle. Ship them to me or him. It's what he does. All this adds up up to rather less than "thousands" and "hundreds" of hours. Though for real quality I'd budget quite a bit more than one afternoon for empirical measuring. If you make a friend who has one the high dollar suspension programs who would run the measurements through to make sure you are likely to get the desired results without causing any ill effects then that would be a really good idea. A certain person springs immediately to my mind, being the owner of such a program, also the owner of a HIGHLY modified 67 Mustang, and who happens to be VERY competent on the subject of modified suspensions. He'd also be the man on that scrub radius thing. If he would help, who can say, but he's not the only competent person out there.
Finding someone to manufacture them. What? Well who's making your spindles now? I mean, really. They can make a sand cast copy of an orginal spindle but not a modified one? (Which incidentally was welded up solely for such purpose, NOT to be used on a vehicle. EVER. Don't get ideas people) And managing their development and production. Err, what is it you plan to do with your copied spindles? Sell some maybe? I had the impression you intended to manage that deal, what's the difference.
The rack might be out of your league. I understand. It's worth looking at with the popularity of upgrading to rack and pinion steering. Many companies seem to be doing quite well selling them. #1 is likely Total Control/Chris Alston since Shelby selected theirs for the "E" cars. There are others out there, Flaming River, newcomers in Australia and small guy "Randall" all doing business. Plus the Mustang II conversion folks such as Heidt's and Fatman's. All pretty good stuff but with drawback the Taurus solution can defeat. One is expense. The best racks are modified new or rebuilt stock racks. The "modified" part is expensive no matter what else. With modified spindles a rebuilt rack can be sourced for a little as $100. Obviously one of the 1000's of common as dirt junkyard Taurus racks even cheaper. The mounting brackets that I've seen are based on the engine crossmember and relatively simple to make with cheap steel stock and can be constructed as a "bolt on". A big advantage over the Mustang II kits which require major and difficult to reverse modification. Plus a couple of the competing rack systems could take advantage of spindles modified the "Taurus way" since their rack systems suffer some of the same diffiiculties.
The questions posed are rhetorical. No need for reply. You're already doing something pretty worthwhile, can you not see it might be well worth your while? Somebody like MustangSteve, Steve Ainsworth, or even Griggs might think so and beat you to it. If doing such is beyond you, fine. It's probably beyond me too. Maybe. Hmm. I dunno. Who's casting your spindles? Darn, too late, I've already told everybody.
