  • SN95 4.6L Mustang Tech
Firewall Grommet Help!
  • Thread starter Thread starter DocG
  • Start date Start date Feb 18, 2006
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Feb 18, 2006
  • Feb 18, 2006
Ok guys, I need someone to do me a big favor. Can you look under your hood, and on the firewall. On my 04', there is a grommet plug that fits in the firewall on the passenger side, maybe 6-8" down, right behind the black cylinder thingy (not sure its name). I lost mine trying to run a amp power wire through it, and Ford parts couldn't locate the part in their system.
Anyways, does it look like one of these??? These are for a 79-93 so I'm not positive they'd be the same size, but most plugs I've seen are the same size if the shape matches. Can anyone help me out?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 18, 2006
  • Feb 18, 2006
Mine is round, not oval.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Feb 18, 2006
  • Feb 18, 2006
Hmmm...I swear mine was oval.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 18, 2006
  • Feb 18, 2006
Just double checked mine, it is perfectly round. I am talking about the one immediately behind the driver's side valve cover.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Feb 19, 2006
  • Feb 19, 2006
I'll see if I can see the cut-out in the metal for the shape.
Anybody else have any idea? Thanks for your help Kilgore!
J
joekd
51
  • Feb 19, 2006
On my 2000 the grommet is also round, I'm sure of this because I just fed my amp power wire through it last weekend
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Feb 20, 2006
  • Feb 20, 2006
Ok, I looked at mine again. Its definetely oval opening. Passenger side, not far from the top or from the fender. The plug is right between the black cylinder thingy and a wiring harness.
Thanks for your help guys! I was going to run my wire thru there, then dropped the dang plug, and it disappeared forever.
Anyone with an 04....could you take a look!?!?
J
joekd
51
  • Feb 20, 2006
ok my misunderstanding, I missed the word "passenger side" and assumed you meant the typical grommet people use to pass wires through on the drivers side
now I'm gonna have to check again tonight
BooWFO
991
Louisville, KY
Feb 20, 2006
  • Feb 20, 2006
Passenger side is OVAL.
Doc odds are is it is under the carpet and matting material BTW it is a PITA to run through there trust me that is where I got some STUFF going through. it is behind the blower box thingy not much room and the matting/sound deading is on real good there too.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Feb 20, 2006
#10
  • Feb 20, 2006
  • #10
Thanks,I thought maybe I was just going crazy. Well I already ran my power wire a couple months ago, just haven't replaced the grommet I lost. I ended up using a grommet on the driver side for my wire. But I pulled the passenger grommet out (thinking I was going to use that hole), and when I tried to put it back in, dropped it, and it landed somewhere down in the engine bay and got stuck somewhere I can't reach. By now I'm sure its on the side of I-75.
Anyways, do you know if your grommet looks more like the first or second picture above? I'm trying to find one to replace the one I lost.
Thanks!
BooWFO
991
Louisville, KY
Feb 21, 2006
#11
  • Feb 21, 2006
  • #11
I want to say 1st but alast mine is gone into the vast unknown too.
tonys5.0
122
Jacksonville, FL
Feb 21, 2006
#12
  • Feb 21, 2006
  • #12
Napa may have a plug that you can use. When I had my 87 I drilled a new hole in my firewall to run some ignition wires, and battery cable. Napa had plug grommets that fit. Otherwise a small shot of spray foam will take care of it.
  • Gulftown980x
  • Jul 29, 2026
squeak93
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
