Firing Order HELP!!!
  • Thread starter Thread starter SLEEPERstang21
  • Start date Start date Sep 10, 2004
SLEEPERstang21
204
Sunny California
Sep 10, 2004
  • Sep 10, 2004
I have a '67 with a 289 in it. Just yesterday, I replaced my spark plug wires with new ones. With the new ones, it seems that my car runs very sluggish and idles very low. What could be the problem? firing order? bad wires? Does anyone have a diagram for the firing order on a 289??? I need visuals....
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Sep 10, 2004
  • Sep 10, 2004
if your sitting in the car 1234 are on the right,5678 are on the left.
D
drutt
  • Sep 10, 2004
Prob' a stupid question but...
How do you know which connector on the distribtor cap is 1,2,3 etc? or does it not matter as long as you connect them in order clockwise?
(as you can tell i am very new to all this!!)
66P51GT
721
Cerritos, CA
Sep 10, 2004
  • Sep 10, 2004
You have to make sure the engine is at Top Dead Center (TDC). Pull the distributor cap and look where the rotor is. This is the correct location for the #1 wire. Rotor spins counter clockwise so add the wires in the correct order 1-5-4-2-6-3-7-8.
TDC is the top of the compression stroke. To find TDC, remove the passenger side valve cover and use a 11/16 socket to manually crank the engine. You can also use a remote starter to tap the engine over. Once you see the intake valve close, rotate the engine until the timing mark is at 0* (TDC).
It's been a while for me but that should do it.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Sep 10, 2004
  • Sep 10, 2004
HE has to be close or it wouldn't run, so he can just bring the timing mark up, it will either be at #1 or 180 degrees off.
D
drutt
  • Sep 10, 2004
Sorry i jumped the thread... SLEEPERstang21 has a different problem to me..
I am having trouble getting my 351w to start... think i may have the wiring wrong... its also got a 302 cam so i guess i should be using the firing order from a 302 not a 351?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Sep 10, 2004
  • Sep 10, 2004
that's possible the cams are interchangable.
O
Ozsum2
695
  • Sep 10, 2004
Would it run at 180* off? Might try to blow the carb off.
J
Which cylinder is which? 3.8L 2004
  • joeybuddy96
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 24, 2026
joeybuddy96
J
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
