First Build
  • Thread starter Thread starter Mario88
  • Start date Start date Feb 12, 2015
  • 7
  • 8
  • 9
  • 10
  • 11
First Prev 9 of 11 Next Last
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 18, 2015
#161
  • Apr 18, 2015
  • #161
For a h/c/i install I'd run at least a 70mm MAF(Pro-m),70mm tb(I prefer Accufab),and 24-30#inj and at least a 155lph fuel pump. If you are running the typical around 400-500 rwhp blower set up, upsize the inj to 42-60# and the pump to a 255-340lph. If your staying with the basic h/c/i build and aren't concerened about the few extra hp and the clearance issues,I'd go with shorty headers, but if you want to eek out all the power you can... Go long tubes imo.
Reactions: Mario88
Mario88
74
12
18
Apr 20, 2015
#162
  • Apr 20, 2015
  • #162
Thoughts on tbody and injector size?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 20, 2015
#163
  • Apr 20, 2015
  • #163
Post above yours solid Advice was given
Reactions: Mario88
Mario88
74
12
18
Apr 20, 2015
#164
  • Apr 20, 2015
  • #164
Wow... Apparantly I did not see that post, apologize A5
Mario88
74
12
18
Apr 20, 2015
#165
  • Apr 20, 2015
  • #165
What's h/c/I A5?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 20, 2015
#166
  • Apr 20, 2015
  • #166
Mario88 said:
What's h/c/I A5?
Short for heads cam intake
Mario88
74
12
18
Apr 20, 2015
#167
  • Apr 20, 2015
  • #167
I knew I'd feel dumber after that...
Reactions: A5literMan
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 20, 2015
#168
  • Apr 20, 2015
  • #168
Lol I didnt know the "lingo" when I first joined this site either. Well not all of it at least. Good luck on your build and don't worry about asking questions ever. That's how we all learned
Reactions: TOOLOW91 and Mario88
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 20, 2015
#169
  • Apr 20, 2015
  • #169
Yup Esp that your willing to actually listen
Reactions: A5literMan and Mario88
Mario88
74
12
18
Apr 20, 2015
#170
  • Apr 20, 2015
  • #170
Accufab ordered today... Is header brand important?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 20, 2015
#171
  • Apr 20, 2015
  • #171
Like most other parts, you get what you pay for. If you are going with shorty's, the best IMO are Ford Ceramic. Pricey but you can also get used ones for 1/2 price of new. For LT, if you have a T5 then the best are either Kooks or Hooker. BBK are decent. Avoid MAC.
They make different LT headers for AOD than T5 as the AOD case is wider.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 20, 2015
#172
  • Apr 20, 2015
  • #172
Eh kooks look beautiful but fitment is hit or miss . My bbk longtubes fit perfect as well as the shortys
Mario88
74
12
18
Apr 21, 2015
#173
  • Apr 21, 2015
  • #173
Finished cleaning this 97 explorer intake... Will this be a direct replacement or is there modification required?
Also, probably a dumb question but injectors, new or used?
A5, you reccomended 42-60lb injectors, is there a reason I shouldn't get the larger right away? Is there such thing as too much injector?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 22, 2015
#174
  • Apr 22, 2015
  • #174
42-60 lb injectors on a stock motor is WAY to much injector you will have starting issues ,idle issues etc without a tune . The explorer intake is a bolt on deal . The elbow for the explorer throttle body comes off and the studs from the stock intake go in the bolt holes . If the lower isn't tapped for the act sensor most guys extend the wire and put it in the air box or the tube going to the throttle body. Either way you need it or the car will deff run like crap .
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 22, 2015
#175
  • Apr 22, 2015
  • #175
The 42-60 is only if you have the blower already and you would need a tune. You can run a big injector on a h/c/i build also if you have a tune designed around them. But there can be start issues and other problems if not done correctly. If you aren't going to be using forced induction(blower/turbo) for awhile just get the proper sized inj for the present combo. For the typical trick flow/AFR head combo/stock shortblock you'll need 24#inj. If you're going with a more aggressive head/cam you might need 30# inj. It ultimately depends on how much hp you're making. As far new vs used it all depends on individual preference. I bought bnib 30# on the corral and saved 100$ over new. 24# inj are very very common and can be hade for cents on the dollar used.
Mario88
74
12
18
Apr 22, 2015
#176
  • Apr 22, 2015
  • #176
I have the vortech v3sc A5
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 22, 2015
#177
  • Apr 22, 2015
  • #177
Get a MAF and some 42's and grab a tune. 60's would be overkill and unnecessary for your power level.
Reactions: Mario88
Mario88
74
12
18
Apr 23, 2015
#178
  • Apr 23, 2015
  • #178
Aeromotive stealth 340 for 75$? Would that be a good setup?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Apr 23, 2015
#179
  • Apr 23, 2015
  • #179
Yup . That's what was in my car with my blower setup on my stock motor
Mario88
74
12
18
Apr 23, 2015
#180
  • Apr 23, 2015
  • #180
So... For what I'm doing, should I do anything as far as pistons/rings or cylinder work? Or will I be fine with bolt ons and tune? 80k orig mi.
  • 7
  • 8
  • 9
  • 10
  • 11
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
