- Jul 10, 2007
- 4
- 0
- 0
I just pulled apart my first engine which was an '86 5.0HO, no problems with disassembly took about 2 hours. I'm going to start with the block and start all over, everything new except for the crank which will be machined and re-used along with a few other misc parts that can be salvaged. I'm looking at around 400 hp and about the same for torque give or take. I am going with Fuel Injection. Probably look at aluminum heads and get a packed heads an cam because this sounds like the best way to match parts. Also go with all after market intake performance parts and exhaust.
The block goes in to the machine shop next week for a clean up and all the needed machining work. This will be my first build - I'm looking for any advice on how to go about researching and choosing parts as well as any first timer assembly advice once I have the parts. Any information would be appreciated as I am looking for a direction to go.
Once the motor is done I'm going to look for a high mileage decent body 5.0 to put this engine in. I do have some freinds with experience that helped me tear it apart but I always like to go out and research on my own. Any advice or knowledge would be much appreciated.
