- Jan 11, 2006
- 264
- 0
- 16
okie dokie, so i installed a new black magic flex a lite electric fan in my 90 5.0. the installation started out very well, everything was straight forward. looks great and the fan came with a complete set of hardware. i bought a new toggle switch, only to find out the hard way that the switch was faulty. it was stuck kinda between on and off so apparently it caused a short. long story short, new toggle switch fried like an egg along with the igniton feed wire. i found the bad wire ( after many many posts on stangnet and MUCH profanity ) and i fixed it. now, the car is running fine and the fan is working like a charm. i can tell a definite difference in the pick up when i hit the gas. there is a bit more of that sotp feel, and i can tell it pulls a little harder on top end. most noticably, the engine revs a bit quicker, which i expected. makes me wonder how fast it will rev when i install my new ported e7te's with 1.7 fms roller rockers. can you say tiresmoke?? the fan is easy to adjust and unclutters the engine compartment. monday i am ordering a higher output alternator from summit and a new battery - mine is almost four years old. the fan does not create as much of a draw on the charging system as i had anticipated, but i like to install things to last so i am going to upgrade my charging system a bit. in a couple of weeks i will be installing a new welded all aluminum radiator. let's see what happens then. ( that means let's see if i break anything else )
