  • 2005 - 2009 Specific Tech
First Mod?
  • Thread starter Thread starter 01YellowGT
  • Start date Start date May 26, 2008
1 of 2 Next Last
01YellowGT
193
Rochester NY
May 26, 2008
  • May 26, 2008
Guys im getting an 08 Candy Red GT this Wed. I was wondering what my first mod should be. Would like somthing that will be reasonable yet make a difference. Any suggestions?
Thanks
V8JamesGT
218
May 26, 2008
  • May 26, 2008
Most people suggest an Intake and Tuner from Brenspeed or Bamachips. It was my first mod and is probably "the best bang for the buck" mod. If your worried about it voiding your warranty you should contact your dealer. Other great mods are Gears, UD Pullies, and Suspension.
klaw
343
Calgary, Alberta, Canada
May 26, 2008
  • May 26, 2008
Thanks
Lower it.
P
PSYKOSTEVO
Banned
Apr 11, 2008
194
  • May 26, 2008
91 octane tune and intake, best mods to date. exhaust is good too but as a second mod.
wusthof
192
BC, Canada
May 26, 2008
  • May 26, 2008
I am in the same situation you're in - me personally, I'm gunna put an exhaust on it 1st, then an intake. The car has enuf grunt to keep me happy for as while, but a better exhaust note needs to happen. I was dead-set on a Pypes MM system, but I' ve starting to hear about quality issues + as Flowmasters have always been in my heart, it's getting tougher w/o hearing it in person. Watch out for the warranty issue tho - if the dealer catches wind of another tune, even tho you've changed it "back to stock", you'll run into sum serious problems imo. Exhaust, intake, then gears for me in the performace aspect of things - 20" wheels would be nice, but with a 1yr. old..............nuff said. My .02
C
COBESGT
231
Dubuque, Iowa
May 26, 2008
  • May 26, 2008
IMO, Intake and Tuner, 20 - 30 HP. The factory exhaust sounds/flows really well for stock and you really won't gain much more, if any HP by swapping that. Pulleys are another easy option and give you 10 HP. A Performance Shifter and Lowering Springs are also other great options. Hope this helps.
SpartaPerformance
2,517
61
89
Long Island NY
May 26, 2008
  • May 26, 2008
Cold air intake and tune is always 1st mod.....most power gain for the money!!
O
Oettinger
10
Toronto, Ontario Canada
May 26, 2008
  • May 26, 2008
I would say suspension should be the first mod. That is definitely going to be my first mod on my car as the stance and handling is always a priority. Going to need to look for some coilovers soon.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
May 27, 2008
  • May 27, 2008
Power=tune/CAI
Handling & looks=suspension
Sound with a hint of power=mid pipe swap and/or mufflers
BudgetPlan1
38
NE Ohio
May 27, 2008
#10
  • May 27, 2008
  • #10
Picked up a new GT 5-speed about a month ago;
1. Bassani axel-bak for sound ($541)
2. CHE K-Brace w/ torque limiters so not to miss 2-3 at WOT ($150)
3. C&L Intake w/ Brenspeed 93 Octane tune combo ($650)
4. 3.73 FRPP gears ($500) to come.
#3 made an incredible difference in driving characteristics of car; I expect #4 to make a noticable difference as well.
Ran the car at ~950 miles on the odo w/ only #1 and #2 above, 14.1@99mph at a track that actually went uphill at the end and also forgetting to turn off TCS.
I figure w/ the 4 above things I should be able to get in low 13's on a really good weather day with some vastly improved driving.
Things I thought about but probably won't do:
1) LT Headers; I dunno, I'd probably go with ARH (expensive) as opposed to OBX (less pricey) but I don't know about if the gains are worth the $$; also we have emissions testing here and that would fail visual.
2) Mid-pipe/X-pipe w/ hi flo cats: Most likely won't gain much, emissions testing issues
3. UD pulleys: Small gain, albeit not much $$, don't wanna bother with it
With the 4 things above, car is fun to drive, sounds good (not too loud) and is reliable and easily returned to stock. Good enough for me. There's always gonna be someone faster, I just want to be able to beat my wife in the Vette on the occasions she's napping at the line. Besides, I think once you get into too much powere, traction becomes a real issue and I don't wanna start in on the suspension.
FR-S8N
1,306
McAllen, tx
May 29, 2008
#11
  • May 29, 2008
  • #11
where did you get the intake and tuner combo from?
BudgetPlan1
38
NE Ohio
May 29, 2008
#12
  • May 29, 2008
  • #12
www.brenspeed.com
FR-S8N
1,306
McAllen, tx
May 29, 2008
#13
  • May 29, 2008
  • #13
what do 2005 auto GT's run at the track with no mods?
NastyStang113
1,567
Florida
May 29, 2008
#14
  • May 29, 2008
  • #14
Mid to Low 13s. I know this isn't stock but just to give you an idea. I've got a buddy who has ran consistent 12.8s with a virtually stock car other than his VMP 93 octane tune and K&N CAI. The tune isn't even a dyno tune !!
dc06gt
24
Jersey
May 29, 2008
#15
  • May 29, 2008
  • #15
My first "mod" was actually an 8" antenna just cause the stock one i think is way to long. I would actually say either a CAI and a tune or a short throw shifter.
wusthof
192
BC, Canada
May 30, 2008
#16
  • May 30, 2008
  • #16
ok.....................tune this, tune that - how bout I'm not going to or even think about running premium go-go gas @ your calculated $6.00+ per gallon. besides the fact of clearing codes ( I plan not to throw any), and turn off O2's (I need cats for emissions), what would an 87 octane tune do for me.....................realistically - is it still worth the bux if there's no way in hell I'm gunna run premium fuel?
C
COBESGT
231
Dubuque, Iowa
May 30, 2008
#17
  • May 30, 2008
  • #17
You have the same thoughts I did before I purchased my tuner/tunes. I had a K&N CAI and finally decided to purchase the JLT II CAI and SCT Tuner/Tunes from Brenspeed. WOW, I was pleasantly surprised at how much different the car ran! Your rpm's stay higher longer when shifting gears, your rev limiter is raised higher 6850 rpm, you get more timing, etc, plus you can use the tuner to check/clear codes, change optional parameters (tire sizes, gear changes, etc). So far I have not had any problems with my tuner, no check engine lights. I was a little hesitant at first, but I love this thing now! And since gas prices just went to $4.02/gallon here for 87 octane, mine is staying on the 87 tune.
FR-S8N
1,306
McAllen, tx
May 30, 2008
#18
  • May 30, 2008
  • #18
the package on brenspeed is now with a BBK intake system and SCT Xcaliber 2. Is this the same thing?
JOEGTS
153
Port Saint Lucie, FL
May 30, 2008
#19
  • May 30, 2008
  • #19
That was actually the first thing I changed aswell oin mine. I then went with what everyone else reccomends. I got an intake and tune from Bamachips and couldn't be happier.
wusthof
192
BC, Canada
May 30, 2008
#20
  • May 30, 2008
  • #20
are there any power increases with the 87 tune or is it a drivablitiy factor (rev limiter, getting rid of the lag in accel. etc.)? I run a 90 octane up here.............a certain gas company sells it for an 87 price. will the 91 octane tune run on 90 octane............. i'm assuming the 1 octane point rating does matter. TIA guys
1 of 2 Next Last
D
08 Turbo kit. Who made this???
  • Don7Up
  • Oct 3, 2026
2005 - 2014 S-197 Mustang -General/Talk- Saturday at 12:24 PM
highplace11
H
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Friday at 12:37 PM
2000xp8
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
