I haven't had my car running in about a month it runs for a few minutes and dies quickly and idles like crap while its running.. I havent really had much time to work on it, been working alot of hours. I did manage to do most of the starts but doesnt idle checklist except the part that requires a multimeter which I also picked up yesterday anyways.. I checked the codes with the key turned on and I got :
81 O - Air diverter solenoid fault, intake air control circuit fault / air injection diverter
82 O - Air diverter solenoid circuit fault, Intigrated relay control module
85 O - Shift Solenoid 4/3 - 4/3
66 C - VAF/mass air flow sensor fault, below minimum voltage
Also I unhooked my battery and checked the volts and it slowly trickels down does this mean my battery is no good? I had 12 volts when I started this test on the battery, also do these codes mean that I probably have issues in the wiirng harness? and how do I use the Multi meter to check everything this is my first time trying to diagnose a wiring problem, Thanks for any replies!
