  • 1994 - 1995 Specific Tech
first time using vacuum gauge
  • Thread starter Thread starter legalize420
  • Start date Start date Aug 13, 2005
legalize420
1,541
South Florida
Aug 13, 2005
  • Aug 13, 2005
i just picked up a vac/fuel gauge and i have a few questions. where is the best place to connect it to? also, what is a good reading on the gauge? thanks
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
The vac tree works for me. Look for 15-20 in-hg.
Good luck.
legalize420
1,541
South Florida
Aug 13, 2005
  • Aug 13, 2005
what about the fuel. where do you connect that and what reading?
HoofnIt
1,175
North Carolina
Aug 13, 2005
  • Aug 13, 2005
The fuel pressure can be checked at the schrader valve on the front part of the passenger side fuel rail. Just remove the cap to gain access.
legalize420
1,541
South Florida
Aug 13, 2005
  • Aug 13, 2005
whats a good reading on the gauge
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
For FP, at simulated WOT (vac line off and capped), 38-39 PSI is stock.
With the vac line hooked up (as it is when you drive the car), 30+ PSI is within spec.
Good luck.
legalize420
1,541
South Florida
Aug 13, 2005
  • Aug 13, 2005
Good luck.
if i use the schrader valve as mentioned above, which one would that be. you lost me on this.
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
Cool, that is what I was trying to do.
J/K. Hook your gauge up to the Schrader valve (looks like a tire's valve). Start car, check for leaks. If safe, Note the pressure with the car idling. It should be 30-34 PSI.
Now remove the vac line on the FPR, and cap the line with your finger (cap the rubber line, not the hard fitting on the FPR). The pressure should shoot up to 38 PSI+. This latter reading is a simulation of WOT (at WOT, there is very little manifold vac, and by removing the vac line, you simulate that condition as far as the FPR is concerned).
Cool? If not, post and I or someone more articulate can help.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:37 PM
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
