five lug brakes help
could you clarify exactly what you mean there?
if you're talking about the splash plates to keep debris from getting on the disc, then yeah, you should probably install it-unless it's all messed up, or won't go on due to interference
if you're talking about the mount bracket for the caliper, then of course, you have to install it prior to the axle install
txstang84 said:
every rear disc setup i've seen has the caliper to the rear
That's true of RWD cars.
FWD cars have the calipers towards the front of the car.
As far as Mustangs are concerned, the calipers are towards the rear front and rear.
I beleive 2005 Mustangs have the rear caliper ahead of the wheel
