  • SN95 4.6L Mustang Tech
Fixed my front end squeeeeeekkkk!!
  • Thread starter Thread starter USMC03GT
  • Start date Start date Aug 10, 2004
USMC03GT
144
Jacksonville, NC
Aug 10, 2004
  • Aug 10, 2004
I had the usual annoying as hell front end squeek. I was in Lowes today and saw a can of spray white lithium and decided to try it out.
Anyways, I took the spray tube and cut one end at an angle then poked it into the boots of both tie rod ends and ball joints. Sprayed the grease into it until it was full then let the pressure out of the boots. Checked the front end and the noise was still there.
Decided to try the steering rack bolts. As soon as I started loosening the drivers side, squeeeeeekkkk. Took the bolt out of that side and sprayed it down with the grease and sprayed the bushings as well. Put that back together and did the passengers side. Got back into the car and tried it and the squeek was gone!!
If ya got the front end squeek try greasing the steering rack bushings, maybe it will help.
YardSpecial
2,664
MT
Aug 10, 2004
  • Aug 10, 2004
So this gonna last, probably not.......
N
narongc73
146
  • Aug 10, 2004
It'll come back son, real soon.
USMC03GT
144
Jacksonville, NC
Aug 10, 2004
  • Aug 10, 2004
Wow I've had 2 tools reply already. I'm so happy
Guess what. If it comes back, I'll "fix" it again.
P.S. I ain't your son, a s s.
awwyea
170
Central MA
Aug 10, 2004
  • Aug 10, 2004
'Dem ball joints are a toast !!!
twogts4us
4,188
12
79
Dunedin, FL
Aug 10, 2004
  • Aug 10, 2004
Maybe, but at least he found the source of his squeak. Injecting a heavier lube into the bushing might be a more permanent solution.
And maybe this is none of my business, but referring to a 29 yr old (presumed Marine ) man, as "son", is derogatory in my book.
USMC03GT
144
Jacksonville, NC
Aug 10, 2004
  • Aug 10, 2004
twogts4us said:
(presumed Marine )
Presumed correct!!
twogts4us
4,188
12
79
Dunedin, FL
Aug 10, 2004
  • Aug 10, 2004
Have anyone tried using a syringe and injecting a lube into bushings, ball joints or ??? I've heard of others doing this, but I don't know any other details (what type of syringe, type of lube, etc) Heck, here in FL, you can't buy medical syringes over the counter at the drug store anymore - too many druggies.
But I'm sure there's a better way...
M
matsm21
241
Long Island
Aug 10, 2004
  • Aug 10, 2004
thats funny, they give syringes away for free in NY
i got the same squeek though it sucks. I did the same thing and found it was my inner tie rod ends. why the hell doesn't ford believe in grease fittings?
T
Tommy43
#10
  • Aug 10, 2004
  • #10
I'm just a wannabe Mustang owner but it sounds like Anti-seize might
work. They make spray anti-seize. Penetrating Red Grease is very
good also. Both are alot better than White Lithium, just messier.
(Red grease is a mess on door hinges and latches) Might wanna
give them a try.
USMC03GT
144
Jacksonville, NC
Aug 11, 2004
#11
  • Aug 11, 2004
  • #11
This is what I was thinking at first, but I broke a couple of syringes trying to inject the grease. Also, the plastic doesn't like it when you put heated grease into it.
As far as using lithium, it might not be the best to use, but it got the job done for now. At least until I can find a better way to grease the bushings.
J
johnnyboy1111
84
#12
  • Aug 11, 2004
  • #12
squeeks
the hyp-needle grease thing works ,the ones that are made in China wont last , it didnt hurt anything on my 99 but must be done about every 6 months in the ball joints & tie rod ends....I also spray the white lube on all the parts under there while I'm doing the lube trick .......PS I dont think the guy who said SON' meant any harm as its just street slang as " wass-up son! ..lighten up guys its only a chat site.................
H
huesmann
332
#13
  • Aug 11, 2004
  • #13
Because the average Mustang owner isn't gonna bother greasing them up.
YardSpecial
2,664
MT
Aug 11, 2004
#14
  • Aug 11, 2004
  • #14
I am a TOOL????
Fix the problem..............
Greases to not mix Mr. Marine.
Rack bushings will dissolve with oil/grease.
Change them out to black poly, no squeak.
Synthetic or Graphite grease is best to use, not white lithium (waste of time & money)
All old grease has to be removed in order to use newer grease.
The OLDER Tool
mcmmotorsports
689
Danbury, CT
Aug 11, 2004
#15
  • Aug 11, 2004
  • #15
He called you guys tools
MT1083
1,033
Charlotte, NC
Aug 11, 2004
#16
  • Aug 11, 2004
  • #16
While we are on the subject, can someone make a list of things that need regular lubing or maintenance to keep from squeeking? Also the type of grease/lube that needs to be used. What do you suggest Cavallo?
YardSpecial
2,664
MT
Aug 11, 2004
#17
  • Aug 11, 2004
  • #17
Just call him SON !!
I am a Mechanic, so guess it FITS !
The TOOL Master
USMC03GT
144
Jacksonville, NC
Aug 11, 2004
#18
  • Aug 11, 2004
  • #18
Cavallo said:
I am a TOOL????
The OLDER Tool
Well gee, I'm glad you finally decided to enlighten us with your knowledge. Maybe if you had taken the time to explain this the first time you posted instead of some incoherent quip, I would have been more receptive.
I guess we'll see what is going to happen. I'm glad that you've been so helpful in offering advice.
Marks5.0!
640
San Antonio, TX
Aug 11, 2004
#19
  • Aug 11, 2004
  • #19
took mine to the dealer and they replaced my rack bushings and havent had a single noise since. That was back in march
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
