OK, the last problem i need to work out of my engine is an exhaust leak.
There is a leak in the exh. man-to-turbo, AND between the exhaust turbine housing of the turbo and the 90° downpipe section. I will have to remove the downpipe to fix the leak, problem is that the bolts are seized. Any advice on this?
I just finished porting an E6 manifold, so i will swap that at the same time i fix the leak. I will port-match the turbine housing inlet at the same time. should i seperate the housing from the rest of the turbo to do that?
I need to have the gaskets ahead of time, so i need to know, are there gaskets anywhere in the turbo??
Thanks a lot for the help,
-Ryan
-Ryan
Check out my site ( link below), I tryed to post imformation on doing this swap in hopes of helping someone
That is one reason I started my semi big project
