Ok so I had a small spot of rust on my passenger side fender. Started with 220 grit and sanded through the rust. Took like 0.5 seconds to get it gone, was barely on there.. Very minor surface rust. Then I smoothed out the lip of the fender with 400 grit. I then taped it off and sprayed it with primer. After I was done I removed the tape and there is a clear line where the tape was. Anyone have any recommendations on how I can smooth everything out and make it look 1/2 way decent until I can get the car painted? Also I got minor overspray off to the parts where it wasn't taped (Thought I covered enough but apparently not)... What are some easy ways to remove the primer overspray?
