flat top are dished
  • Thread starter Thread starter 351mustang65
  • Start date Start date Nov 21, 2007
351mustang65
  • Nov 21, 2007
what's better and why dish or flat top pistons im not going to be useing Nitrous or supercharger or anything and is this kit worth the money. Stocking, Forged or custom pistons (any stroke or rod), w/plasma moly rings (std-60), Fel-Pro gaskets, Clevite main, rod & cam bearings, High Volume Oil Pump, brass freeze plugs, lifters, Cloyes timing set, performance wrist pins (no cam) $939 or i can get a stock rebuild kit for $329 this is for a 69 351w
StangDreamin'
583
2nd Ocotillo bush east of the Colorado River; Sout
Nov 21, 2007
  • Nov 21, 2007
Can't help you on which kit to get. But, if you're sure you're not going to huff or spray the motor, I'd go with the flat-tops. Dished pistons will increase your combustion chamber volume, which lowers compression ratio - and that generally lowers the amount of potency/efficient use of each of those 2000 explosions per minute (at 4000 RPM). More pressure when it goes bang = more torque (at any RPM) on the crank/clutch/tranny/driveshaft/axle/tires. To paraphrase somebody else's signature line: "Build for torque! Horsepower is something you brag about in the parking lot!"
rbohm
6,698
550
204
tucson,az
Nov 22, 2007
  • Nov 22, 2007
first stay far far away from the high volume oil pump. you dont need it, and it will tear up your distributor gear fairly quickly.
as for piston tops, i prefer either the flattop or a reverse dome piston. a reverse dome is a dished piston where the dish is contoured similar to the combustion chamber shape, and not just a trough cut in the top of the piston. use a reverse dome piston with a small combustion chamber to limit detonation, and keep the compression ratio reasonable. if you have 64cc or larger chamber, then use the flattop pistons.
351mustang65
  • Nov 22, 2007
then when do you need a high volume oil pump? and it comes in the kit i dont know if i can swap it for a diff one are not
rbohm
6,698
550
204
tucson,az
Nov 22, 2007
  • Nov 22, 2007
you need a high volume pump when you have large bearing clearances, and are running thin oil at high rpms. that way you have enough oil volume at the higher rpms to feed the bearings.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
