flex plate installation
97-Blk_GT
15
Im finally installing my 04 4.6 in my 97 GT..the 04' motor came with a new flex plate and it also has a balancing weight welded to it..is there a certain way that the weight have to face..I mean does it go on one way or another..the old flex plate did not have a weight on it with the 97' motor..I dont want to install it wrong and cause any weird vibrations..thanks for any info..
Not sure about yours, however some flex plates will only bolt up one way, meaning the bolt hole pattern may be slightly different between each other. The holes may not be equally spaced apart from each other which would only allow the flex plate to lign up one way. Check yours to see if that is the case. As far as what side faces where, the flex plate is usually marked, engine or transmission side. Hope this helps. Good luck, Tommy.
You can use the flex plate from your 97. The are the same. Gt Tommy is right, they only bolt one way b/c the holes are not evenly spaced.
Look at your old motor if your not sure of which way to bolt it.(hopefully you havn't taken it apart yet)
thanks for the info. and replies..I will have a look at it..I was told when I bought the new engine that I need to used the new flex plate because it is balanced or something...there is a weight on it and not one on the 97'
thanks for the info..the new motor and tranny are in..Ive only been collected parts for a year to put it all together...cant wait to get this puppy on the road..thanks
