Well i have come across another problem trying to get my engine and transmission together. Originally i couldnt get the two mated together because my convertor wasnt all the way back, but i pushed and wiggled on it some more, and it is now where it should be. I can get the engine and bellhousing, and the convertor and flexplate bolted together, but when i start to torque down the convertor nuts to spec.(25 ftlbs) the weight on the flexplate rubs against the engine/block plate, so much you cant turn the engine over by hand. The flexplate is actually deflecting as you turn the engine over, i know this because i had someone turn the engine over by hand, and i placed my finger on the flexplate while it was being turned and it went from being on my finger to 1/2'' gap between the two and back to my finger again. Does that make any sense?
Any ideas as to what is causing this? All suggestions are welcome
Thanks
Thanks
It was the drain plug the whole time
Oh well at least it was a easy fix
