Engine Flo tek heads
rockyracoon
874
27
49
margate NJ
They advise ARP studs, nuts and washers but can I get away with stock bolts and washers. Also is it absolutely necessary to change push rods if I'm keeping the stock cam ? Going with 1.6 rockers. Would the head dimensions be the reason for needing to check push rod length ?
People reuse the stock bolts all the time.
The head is potentially taller though, and you may wanna check for that difference if you still have a stock iron head to compare it against. If that turns out to be the case, ( even if it's small like .030") using the aftermarket rockers will force you to take all of it into consideration with regard to making sure that the pushrod is correct.
Reactions: General karthief
