floating front end
  • Thread starter Thread starter Cobain03
  • Start date Start date Dec 12, 2004
Cobain03
996
Lexington, Ky
Dec 12, 2004
  • Dec 12, 2004
hey guys
i noticed when running about 70 or so the front end feels floating like you are haveing fight it back and forth and when you go over a heel it go off to the side man a funning feeling when running 70 or so i did chang wheels i got a set of mag 500 ( 14 in ) i used my old tires for now maybe thats the trouble wrong tires on these wheels i don't know i think it all started when i put the wheels on it always did hill thing
any ideas????
thehueypilot
1,084
Medina,Tennessee
Dec 12, 2004
  • Dec 12, 2004
Is your front end higher than the back end as in the rear is sagging? When the rear end sags it puts more air under the front end so it acts like a sail and lifts it up (the floating feeling)the faster you drive.
D
D.Hearne
11,730
south louisiana
Dec 12, 2004
  • Dec 12, 2004
Well that's one thing big block Stangs had an advantage over the small block cars---- my 67 427 car didn't float the front end till about 120 mph That "excess weight" helped to keep the wheels on the ground.
66nightMARE
97
Katy, Texas
Dec 12, 2004
  • Dec 12, 2004
Not trying to flame you or anything, but damn dude use periods. It was painful trying to read that.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 12, 2004
  • Dec 12, 2004
I had the same problem so I put on an airdam. Those things make a world of difference.
N
nds03
166
  • Dec 12, 2004
i had that problem when driving from gainesville to west palm. my tires were bald when i got there because one of the ball joints on the steering linkage was bad. you should probobly check that out
rbohm
6,698
550
204
tucson,az
Dec 12, 2004
  • Dec 12, 2004
most cars at that speed have a tendency to generate aerodynamic lift. it gets worse when you pull up behind a large truck and you lose downforce on the front. the solution is to add a front spoiler to prevent air flowing under the car.
Cobain03
996
Lexington, Ky
Dec 12, 2004
  • Dec 12, 2004
ok i am going to put it on a rack this weekdend ....... and check things out . i think it might because on rime and tires. i had rims and hub caps before. so there 's got be something in common???
N
nds03
166
  • Dec 12, 2004
i dont know what your talking about
D
D.Hearne
11,730
south louisiana
Dec 12, 2004
#10
  • Dec 12, 2004
  • #10
He can't help it, he's from Kentucky I've seen a few East Texicans speak that way too. And I know, cause I grew up there.
66nightMARE
97
Katy, Texas
Dec 12, 2004
#11
  • Dec 12, 2004
  • #11
Kentucky hu....well theres your problem right there. J/K It's all good
Pbum5
515
Minneapolis, MN
Dec 12, 2004
#12
  • Dec 12, 2004
  • #12
Cobain03 said:
hey guys
any ideas????
My car did the same thing at speed. I replaced the front coils with 1" drop 620# and it helped a lot.
65fastback2+2
1,229
Louisville, KY
Dec 12, 2004
#13
  • Dec 12, 2004
  • #13
i had both of mine to 115 and it never had that feeling, both had power steering so the steering felt looser, maybe thats what you are feeling cuz you have power steering....
G
GaPonyFarm
663
Columbus, GA
Dec 12, 2004
#14
  • Dec 12, 2004
  • #14
I agree with the above comments.... get the front lowering springs and ditch the power steering, if you can drive without it. My '66 is pretty stable to 120, but is downright scary at 135.... which is where my '03 Mach just starts coming alive....
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 13, 2004
#15
  • Dec 13, 2004
  • #15
SHOCKS! My shocks were worn and it felt like a boat on a river. New shocks, (cheap ones), from Autozone completely cured the problem. This is not to say your tires are not to small for your rims or you may have other suspension problems but that would be my first guess.
I don't remember punctuation and spelling being in the requirements for posting but maybe we should look at that. JK GaPony farm.
Cobain03
996
Lexington, Ky
Dec 13, 2004
#16
  • Dec 13, 2004
  • #16
ok might be the shocks,,, whos knows how old they are really ,,, it might be a little of all need to get it on a rack and see,, but seems like it all started when the new rims went on !!
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
