Oh and also.... what about the seat platform?
If its jsut free should i jsut cut it and weld it to the new floor?
Floor support's (if intact that is)danny clemens said:That's what I've read too. Any insight as to why it won't go in from the bottom if the drive train is removed.
xoxbxfx said:I would do full length not a single entire floor. The cost alone is the big factor. Usually the trans tunnel isnt rusted or anything. I wouldnt mess with it just cause its a PITA. Just patch what you need, why fix whats not bad.
The floor is like a 69... its made of like 3 panels that make up the floor. Its not to bad. Cutting is what sucks. If its a few localized holes in the trunk, I'd patch it with small patches. Can you get some pics of the rust issues?
mustangman70 said:So im assuming that MOST of the welding of the floor will be done underneath correct?
6T6coupe said:Looks like the tunnel is ok and just front and/or full pans might do it. That'll make the job a lot simpler.
Typical coastal rust up higher, though. Luckily, the colw on a 70 is easy to get to, so if you have a leak there, it should be a simpler fix.
I think you're definitely gonna need quarter skins, door skins, maybe wheelhousings and bug spray for the spiders!!
My coupe is getting the same sheetmetal and pesticide treatment!
mustangman70 said:THANKS MAN!!
mustangman70 said:well im at work right now and cant get on aim till i get home
Thanks for the advice...do they make a little patch piece for that area right behind the rear window on the trunk? what about just under the quater window?
My doors are pretty frickin rusted though![]()
