Electrical Florida 5.0 Gauges wiring question
africansnowowl
82
35
28
San Antonio
I bought a basic bezel with turn signals from Florida 5.0. Put Autometer Phantom gauges in, and got them all wired up. The instructions from Florida 5.0 are pretty vague about wiring the alternator wire. It basically just says jump it to a 12v switched. Looking at the back of the stock cluster, it looks like the alternator wire (red/lt green), goes to the "amp" light socket on one side of the bulb. A resistor connects it to the lt green/red wire, which appears to be "ignition switch to alt reg". That wire doesn't have 12v on it with key on though. Anyways I pulled that resistor out of the bulb socket and had those two wires splice together with the resistor in-between. So basically splicing pins 5 and 6 together with the factory resistor connecting them together. Does that sound correct?
Also on the subject of gauge wiring, can I use any 12v key on power source for the gauge power(not the lights)? I found a few things that go into the stock cluster that have 12v key on, such as the tach signal and warning lamps feed. For the lights I just used the brown wires in the headlight switch which I have already tested to work.
Hello there - I'm installing a classic dash gauge cluster with autometer ultra lights and I am having the same issue. Classic dash instructions are equally vague on how to re-excite the alternator. Did connecting pins 5-6 work for you? And did you leave that connection in place or just one-time to get it going?
Thanks. I have a left over ignition wire from the classic dash wiring harness. I'm wondering if I can't just connect that to the Red/Light Green wire. That wouldn't have a resistor, but I think I'll give it a shot.
Needs the resistor to allow the alt warning light to operate and the alt to charge. I have to do this on every holley digital dash I install. 05 up are easier but require computer pwm control.
