  • 2005 - 2009 Specific Tech
Flowmaster American Thunder loose baffle
  • Thread starter Thread starter JTGrant
  • Start date Start date Aug 2, 2007
JTGrant
775
GA
Aug 2, 2007
  • Aug 2, 2007
Just wanted to let everyone here at Stangnet what happened with my Flowmasters. Around 9 months ago my first set of flowmasters started to rattle and buzz around 900-1500 rpm. I called summit and they sent me a new set at no cost.(Had to send the others back). 6 months after that they started making the same noise again. So I called summit and explained to them the situation. So I decided to get the JBA axleback and pay the difference. So I now have the full JBA system. The sound is better with the JBAs than it was with the flows. There still is some resonance around 2500-2750 rpm, but it does sound better. I believe that there is another thread about this issue on another Mustang forum. Not sure but I think this only happening to people that have after market mid pipes and/or headers.
A
ARTTII
272
Detroit, MI
Aug 2, 2007
  • Aug 2, 2007
also happened to kooldawg (sp?) on here, iirc.
That is some poor quality control for what you pay for their stuff...
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Aug 2, 2007
  • Aug 2, 2007
Yes it was me. I have had no problems with my replacement set(since early May). I know it was an issue that Flowmaster has corrected. The muffler shop I got mine from contacted Flowmaster directly and sent me out a set from their CA warehouse(also at no charge). Probably from the "new" batch. IF these do it as well, I will also switch to a different brand
cowtown
228
Victoria, BC Canada
Aug 3, 2007
  • Aug 3, 2007
Gad, why o why do we have to suffer through one of these every month?
JTGrant
775
GA
Aug 3, 2007
  • Aug 3, 2007
What???
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Aug 6, 2007
  • Aug 6, 2007
the only issue i have had with my flows would be rust at the outer case welds. the paint they use does not offer much corrosion protection, IMO. i have an O/O H and have had the flows forever withuot any problems. the two have been combined since march of last year.
kooldawg6
Aug 31, 2006
1,679
Central VA
Aug 6, 2007
  • Aug 6, 2007
My second set have now outlasted the first set. The bad thing about the second set though is the tips discolor(turn brown like dirt, but does not wash off)very quickly(nearly every 2 weeks)whereas the first set never did!!!!!
bigcat
May 1, 2005
3,015
7200 feet
Aug 7, 2007
  • Aug 7, 2007
i use a little wax on them and it cleans them right up.
kooldawg6
Aug 31, 2006
1,679
Central VA
Aug 7, 2007
  • Aug 7, 2007
Thanks! I will give it a try. I have been using Eagle One's Never Dull wadding polish.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
