Flowmaster cat back rotted and a simple tranny question
Camman
1,055
Las Vegas, NV
Hola all long time no c as usual. Lifes been really busy. So I finally am back to work on my stangs, I am working on my newest(purchased in 05) 89 mustang vert. It has a long list of mods one of them being a flowmaster cat back. The thing is really loud and has been since I got it due to the mufflers not actually being used. the cat back is rotted right at the h-pipe, I believe its a bassani h with cats. The collectors are still bolted up, but the pipes broke off right at the flange. It is a two bolt, and one of the pipes has a crack in it about 17 inches long. How should I go about fixing this? I am just gonna go to az and see what they have, but thought maybe you could give me some pointers.
Also, I have not driven any of my stangs for at least 2 years. I pulled this one into the garage, and when at the bottom of my driveway the tranny was not in gear, I had to rev it to get it to catch and then I shot up my driveway and it lost drive again, only for me to rev it and be able to drive in. I know it has a tranny leak, and after 2 years of dripping I am guessing it lost between 1 and 2 qts(judging by the amount in my catch pan). Think I did any damage to the aod? and what kind of tranny fluid do I need to put into the aod. It is stock with a lentech valve body. I really dont want to rebuild the aod... but I guess I will if I have too. Thanks for any help :flag:
Top off the AOD and you should be fine. Take it for a quick drive and see. When I did my VB I had to drive the car to the parts store to get some more ATF since I was about 2 or 3 quarts shy of being full. The car slipped a little when leaving from a stop if you didn't give it some gas but after I filled it up it has been fine since. That was 3 years ago.
So long as you don't do the 1D1 shuffle and no WOT in OD they aren't too bad.
I beat on one of my cars that had an AOD and ended up burning out OD. I drove it for 4 years like that and never had a problem other than no OD, which was my fault for screwing around and doing a couple of WOT blasts while in OD.
