  • SN95 4.6L Mustang Tech
fluid/filter change
  • Thread starter Thread starter jlds91389
  • Start date Start date May 16, 2009
J
jlds91389
241
Orange Tx
May 16, 2009
  • May 16, 2009
i used the search and cant find the exact answer im looking for. i want to know what can i use for fluid? do i have to use straight mercron v or can i use like a dex/merc mix? and im draining the converter to. dosnt my car have a drain plug on the converter.? sorry if these are newb questions
M
mr-mike
122
  • May 17, 2009
yes
I used the older fluid on my 99 , I read later it takes a different type 70,000 miles but no problems so far & yes there is a drain plug on the converter , put a new filter , dont overfill & when starting it let it idle slow till it fills the whole unit .... I always change the tranny fluid & filter & rack steering every 75,000 miles .... it pays off in the long run ... good luck
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 17, 2009
  • May 17, 2009
I believe it says right on the trans dipstick Mercon V. If it asks for Mercon V, use Mercon V. It should be in the owners manual. With my old daily driver I just changed the filer and added 4 or so quarts to get the trans back up to full levels. I had over 130,000 miles on the car, replaced my filter twice and never had 1 problem with the trans. I did use Mercon V tho.
J
jlds91389
241
Orange Tx
May 17, 2009
  • May 17, 2009
^^ i know to use what it calls i was just curious as to if you can you a mixture
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 17, 2009
  • May 17, 2009
I would not mix them. Some mechanics have told me they use different pumps for different rear end fluids. Thats a bit over the top in my opinion but I wouldn't mix different types of ATF together because they don't have the same physical characteristics.
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
T
Service Fluid Recommendations for 2015 Paxton Supercharged GT
  • ThotTrap
  • Aug 25, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 25, 2025
ThotTrap
T
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
