  • 1994 - 1995 Specific Tech
Fluidyne installed, now some ?s
  • Thread starter Thread starter yellowstang1994
  • Start date Start date Apr 30, 2007
yellowstang1994
338
  • Apr 30, 2007
Groundstrap? - My search yielded no results. They say to put one on and attach it to the engine block to prevent electrolysis. I'm worried about screwing in anything to my brand new fluidyne. Did you guys do this and how did you do it?
Mixture? - After reading posts on here and worrying about people saying too much water or whatever can corrode and spring leaks I decided it would be best for a 50/50 mixture. However, after installing my fluidyne the car still runs the same temp? Should I run a diff. mixture?
Oh and fitment for my fluidyne was kind of off. It took me a little more than throwing it in there. I had to wedge it in between the abs box which is touching it it's so tight. I also ended up taking the battery out and tray to fit it underneath that a/c line. It took a little bit though. Just kind of expecting it to cool off a little more than it is. I also have a 180 degree thermostat in there. The car runs constantly at 210 according to my autometer and climbs little higher at a stop light but never cools better than 210. Any more ideas? I'm determined.
badstang123
397
Santa Clarita, CA
Apr 30, 2007
  • Apr 30, 2007
As far as water antifreeze mixture; I don't. I run all distilled water and two bottles of water wetter. It has anti corrosive properties and I haven't had any problems.
I don't think that is the issue with your temps though. I would look into figuring out a way for the fan to come on sooner. I personally, ran a new relay and bypassed the regular wiring. In my car as soon as the ignition goes to the on position so does the fan. I'm sure others will offer other ways of doing this though. Good luck
- Justin
yellowstang1994
338
  • Apr 30, 2007
Thnx, i'll try some water wetter and maybe look into finally finishing that manual fan switch I was thinking about earlier.
badstang123
397
Santa Clarita, CA
Apr 30, 2007
  • Apr 30, 2007
The thing you have to remember is that antifreeze is just that, something to prevent freezing. It actually hurts the ability of water to cool. Some people have no choice depending on where they live. I am fortunate to live in SoCal, so I don't really need any. The water wetter should help some though.
Y
yellow1995Cobra
2,959
Massachusetts
Apr 30, 2007
  • Apr 30, 2007
it doesnt go below 210 even while crusing down the highway? Without the fan set to come on sooner, the car should still run in the 180-190 range while on the highways with all that air flowing through there.. How hot is it where you live now?
HISSIN50
34
129
Apr 30, 2007
  • Apr 30, 2007
Justin's thoughts are very good. As he said, water transfers heat ~2.6 times more efficiently than E/G coolant. My view is a little different on the stoichiometry however. I run no less than 25% coolant and will normally run 50/50, even though I live in the desert (we see highs in the one-hundred teens). I feel that if someone needs to have more water in the system to keep things cool, there's another issue which needs addressing.
I totally agree about the fan control. That will make a large difference. A Dc Control unit works awesome if you want a stand-alone.
I would go ahead and install a Mr Gasket stat if you have doubts about yours. Cheaper stats are not balanced and can suffer from hysteresis. This means they don't always open when they should.
Do also ensure your cap is holdilng proper pressure. 16 PSI in the system raises the effective boiling point about 50*F.
For the ground strap........... um, I dont see a ground strap *preventing* electrolysis (perhaps galvanic corrosion would be a better way of stating it). The strap simply provides a ground pathway. I'd like to not have any current in the electrolyte but short of that, a ground strap is a good idea IMHO. Does your radiator have mounting tabs for the fan (fans themselves can cause electrolysus - a useless factoid)? I would run a little braided (but insulated for chafing concerns) strap from a metal mounting tab on the radiator to the body.
Good luck.
badstang123
397
Santa Clarita, CA
Apr 30, 2007
  • Apr 30, 2007
It's in the 80's. I also run a 160 degree thermostat though. As you will see following that statement, many will tell you, you shouldn't. I'm not recommending one way or the other just letting you know my experiences. It runs very cool the way I have it set up but if it's hot and I push the car hard, it will get hotter even with the lower thermostat, Fluidyne, fan wired on and new water pump. I think our cars have problems with the way water flows through the block. But I don't have any specific evidence to support this. I just don't see how all kinds of stock cars always run at the same temp regardless of how they are driven and our cars have so many problems even for those who have upgraded. That's the only other thing that I think could be a problem.
- Justin
C
cbarr300
746
goose creek, SC
Apr 30, 2007
  • Apr 30, 2007
FWIW, the low speed fan comes on at 208 on t4mo computers. The high speed comes on at 224 IIRC.
I'd try installing a manual fan switch and see what that does for you. (Don't leave it on high all the time..and if you go to the high setting, make sure you're in "low first" so the fan gets up to speed. Otherwise the fan may catch fire)
I have a fluidyne, 50/50 mix, stock waterpump. I adjusted my fan temps with the tweecer to come on much earlier.My temps range around the 180-190 mark on a 90* day. It sometimes will crawl up to 198...but never past 200. I attribute this to the CRAZY underhood temps the car has. It climbs up to 120 or so with the AC on.
best of luck
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
May 1, 2007
  • May 1, 2007
our block design is no different than the previous body style. the only difference is the timing cover, water pump, and accessory brackets. the focus of the blame IMHO would be the poor design of the front bumper which doesnt allow sufficient airflow. i have a fluidyne radiator, 180* thermostat, 70/30 mix favoring water, and the tweecer turning the fan on about 20* eairler than normal. i havent had any cooling issues at all. i also live in south florida where the average temp during the summer is in the high 80's, low 90's.
C
cbarr300
746
goose creek, SC
May 1, 2007
#10
  • May 1, 2007
  • #10
also, something I forgot to mention...
look under your car by the radiator and see if you have a little black piece under the radiator. That's the air dam thing and it forces air going under the car back across the radiator at speed.
badstang123
397
Santa Clarita, CA
May 1, 2007
#11
  • May 1, 2007
  • #11
This is entirely possible. I've been running my car without the air deflector because I never really knew it was missing. It's on the way in the mail as we speak so I'm hoping this helpful when I'm pushing the car hard since that is the only time I run into a problem (Plus I've already done everything else I can).
- Justin
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 1, 2007
#12
  • May 1, 2007
  • #12
- Justin
Ever since I put the Xenon front lip, (and it blocks the dam) My car runs warmer. I cant take it off now b/c the car looks like crap with the front missing. One day, I will replace the bumper and the lip with a replacement Xenon Bumper.
RC
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
