Wonder, if anybody knows how to install flywheel in correct position? I have 289 engine with 28 oz flywheel. I am doing auto trans to T5 swap and I didn´t mark position of flexplate before. Anybody can help?
Be careful here, you need to make sure to use a 28oz flywheel on this motor. The motor the T5 came off of was most likely a 50oz imballance. If you are using that flyhweel then you need to have it reballanced.
It's even harder to get right with a flexplate if you still have the reinforcement washer that goes between the bolts and plate. As zookeeper & the others have said, all the holes line up one way, no way to get it wrong
