flywheel tech...
  • Thread starter Thread starter Paulywalnuts446
  • Start date Start date Jun 28, 2005
P
Paulywalnuts446
84
  • Jun 28, 2005
ok I need help , so i got this flywheel from Ram its right for my setup, the only thing its 164 tooth instead of the 157, and it seems everyone is using the 157 with a 10.5 inch clutch.i wanted to know whats the benifit of going with the 164 tooth flywheel? i know if i use the 164, which is 11 inch instead of 10.5 i have to use a 11 inch clutch, should i just stay with the 164 or get a 157? its going on my 331 5spd. am i going to have trouble with any other aspect of the install like the bellhousing, clearance?? or anything like that
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 28, 2005
  • Jun 28, 2005
You might need a different starter. Why did you get the larger flywheel?
txstang84
1,639
42
69
Tuscola, tx
Jun 29, 2005
  • Jun 29, 2005
X2...it's not quite right for your setup...the bell for a t-5 is setup to use a 157 tooth wheel...the starter engagement is determined by the bell's starter mount angle. i'm had a similar dilemma with a c-4...i wanted to run a 157 tooth flexplate, and discovered i had to use a 164 because of the bell...which also alters the bolt circle diameter on the t/c i had to use
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
4.6 need advise on flywheel different engines
  • Creomod
  • Jun 14, 2024
1996 - 2004 SN95 Mustang -General/Talk- Jun 14, 2024
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
1969 clutch and flywheel
  • 78 Mach1
  • Oct 30, 2022
Classic Mustang Specific Tech Oct 30, 2022
78 Mach1
