Fog light issues
  • Thread starter Thread starter SNStang50
  • Start date Start date Jul 5, 2011
SNStang50
286
Cinnaminson, NJ
Jul 5, 2011
  • Jul 5, 2011
So my 91 GT verts fog lights aren't working...i just replaced the bulbs today to rule that out, and i'm putting the passenger side light back in tomorrow....any reason the driver's side wouldn't work without the passenger side in, or should I start looking elsewhere for why these things won't turn on....thanks guys!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 5, 2011
  • Jul 5, 2011
Be careful not to use bulbs rated at more than 55 watt each. Using oversize bulbs can result in overheating the wiring harness and electrical fires. Definitely do the fog light fix.
SEE Mustang GT Fog Light Fix to fix the problem. The stock wiring isn't up to the job and is overheating. The headlight switch & turn/multifunction switch are affected by Ford's wiring problem. Sometimes it overheats so badly that the plastic shells of the wiring connectors start to melt. This will show you how to add a relay to the fog lights to relieve the overload on the headlight wiring.
I did mine differently, but I had to build my own wiring harness for the fog lights. This is more trouble than it is worth for most folks. I left all the wiring on the stock light switches in place and used the fog light wiring to power the relay coil. The other side of the relay coil is connected to ground. I have an inline fuse that picks up power from the battery side of the starter solenoid. It is connected to the relay contact. The other relay contact is connected to the new wiring harness I made for the fog lights.
The advantage of making your own fog light wiring harness is that you can run 100 watt fog light bulbs. The stock wiring harness will not use 100 watt bulbs without overloading and causing a fire.
Unless you are good at electrical wiring, have the skills and tools (crimp tool, soldering gun, heat gun for the heat shrink tubing, etc.) I recommend that you stick with the Corral method.
Technical explanation of why the wiring and switches overheat.
You asked for it...
I= Current
E= Voltage
R= Resistance
W= Watts
Two 55 watt fog lamps =110 watts. Find the current in the circuit
I= W/E
110 watts/14 volts = 7.85 amps for fog lights alone.
Since the lighting circuit supplies headlights, taillights, and parking lights, etc.
56 watts 2 each GE Part # L3156 corner light 28 watts each
90 watts 2 each GE Part # 9004 headlight 45/65 watts each (low beam)
63 watts 2 each GE Part # L194 parking light 31.5 watts each
56 watts 2 each GE Part # L3157 tail light 28 watts each
265 watts Total
Total other exterior lighting current
I=W/E
265 watts/14 volts = 18.92 amps
18.92 amps other exterior lighting current
+ 7.85 amps fog light current
26.77 amps with all exterior lights and fog lights on.
The 12 gauge power feed wire to the exterior lighting switch is rated at 20 amps
26.77
- 20.00
6.77 amps excess current
7.85 amps used by fog lights
-6.77 amps excess current
1.08 amps to run the fog lights left if you stay within the 20 amp limit of the wire.
With 1.08 amp of current, the fog lights probably won’t produce any useable light.
Added resistance required to reduce fog light current to permissible 20 amp limit
R=E/I
14 volts/6.77 amps = 2.06 ohms
Resistor wattage
W=EI
14 volts x 6.77 amps = 94.78 watts
You would need a 2 ohm, 100 watt resistor.
Light bulb ratings from http://www.roadparts.com/catalog/section30.pdf
Radio shack resistor catalog - no matches , and no combinations that could be used to make a 100 watt, 2 Ohm resistor.
See RadioShack.com
Ohm’s law – in case you have any questions about my formulas - Ohm's Law Calculators
SNStang50
286
Cinnaminson, NJ
Jul 5, 2011
  • Jul 5, 2011
Well I checked the harness connectors and nothing looked wrong there...this car is completely untouched, and the bulbs i used to replace what I assumed was a bad bulb is the same size, and the correct 912 bulb that the car calls for....I put the new lenses on b/c they were broken, and from talking to a few friends, I'm kind of wondering if the switch itself might be bad...
Beasty306GT
671
Oxford,Mass
Jul 5, 2011
  • Jul 5, 2011
pull the headlight switch out and see if its melted or burned
HISSIN50
34
129
Jul 6, 2011
  • Jul 6, 2011
Is the fuse for the fogs intact? Have you checked I/O power at the fog light switch?
SNStang50
286
Cinnaminson, NJ
Jul 7, 2011
  • Jul 7, 2011
Thanks guys...Hissin..right on...I actually jumped the fog light power w/a paper clip and they came on, so lo and behold, fust #15 was out.....had no idea they had a dedicated fuse just for the fogs...thanks again! Oh, and i'll probably rewire them eventually to avoid any future issues, just glad they're on now....speaking of fuses....any chance the trunk hatch release has it's own fuse as well? just wondering b/c that's not working...lol
HISSIN50
34
129
Jul 7, 2011
  • Jul 7, 2011
It should be fuse 6 if you wanna check on it. The button might have simply gotten wonky. You could test for constant power into the button and jump the wires to see if it excites. If yes to both but the button does not pop the trunk, remove the button and test continuity with the switch closed (button depressed).
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
